| Ive also been having electrical problems this winter. Last night I was driving back home down non-lit country lanes and all my electrics stopped working one by one - 1st the ABS, then the radio, wipers, power steering, heater, clock and finally the headlights! Couldn't see a thing and luckily managed to pull into a layby. I waited there with the engine running and all other electrics off for about 1/2 an hour, after which all the electrics suddenly came alive again. Had exactly the same experience back in November and the car went to BMW. They tested the battery / alternator and could not find anything wrong. Being a JCC race car it is fitted with a battery isolater , but I am certain that is not the problem in my case. Monsta, I reckon in both of our cases it is a problem with the alternator - JCW did say to me that they heard an intermitant strange sound coming from mine when they had the car for a period of time late last year, yet BMW did not agree. The alternator is probably not charging the battery as efficiently as it should. Therefore when you use headlights / wipers / heater, etc in the winter months it results in a sudden decrease in battery power. I might be wrong, but I can only pin point the problem to the alternator. Last edited by Speedster; Feb 8th, 2004 at 05:26 PM. |
| Being in need of a new alternator I was suprised to find out that there is more than one type ! presumably taking into account how many power sapping optional extras you have !? PS Speedster probably just a side effect of driving with one wheel on the grass verge as oppossed to the tarmac all the lectricity has drained to the right side of the car away from the battery |
| I had this problem on my first mini. My battery went flat after only standing for 3 days over christmas ( 02 ) called out mini service and they just boost started it, only for it to go flat again a few days later so called them out again so they boost started it once more and told me to book it in at the dealers. So in it went for them to tell me it was the battery the had gone down. So all was fine until this christmas even though it had stood for over a week in the summer while on hoilday it went flat after only standing again for about 3 days. Called out mini service who boosted it to get it going. And they told me it maybe the mindisc head unit apparently they can drain the battery if the temp drops below 0'c so he showed me which fuse to take out, which solved the problem. Traded it in a few weeks later so not sure what they did to it in the end. ![]() |
| Thanks for the info, I have a suspicion that it will turn out to be the minidisc player but I'm a bit worried they won't replace it as I had a CD player in there as standard (which was replaced as part of a recall) and it's possible the minidisc wasn't recalled whilst in the previous owner's possesion. Any opinions on this? In theory it should be covered by warranty as it's a BMW/MINI product still despite having changed owners. Oh well, time will tell... back to the dealers this week.. the MINI has gone... |
| I would tell them that you think it is the mini disc player becuse a "friend" had the same fault and it was the minidisc player. Let them tell you that it is not covered under warranty. As you said it is still a MINI product and it is faulty, what would happen if you bought this unit from them as a spare part? would they warranty then ![]() Any way it should be Apline (the OEM MFG) that should be paying for these faults, not BMW nor the owner. |
well, i have had a problem with the battery aswell, when i bought the car i could not test the sat nav cos the battery was flat, the dealer said that it had only been on the forecourt for a week. I have fitted a stereo to it, and it all seems to work fine. but i did sit in the car one day for about 2 hours with the music on quietly, and when i went to drive off the batery wa sflat, luckily i was on a hill and i could roll off to go!!. but then about 3 days later the battery was flat again, and the indicator was black. i have heard that the sat nav takes alot of standby battery life when you are not moving. Is this true?? and do any of you guys have sat nav? For Car Audio, Car Destruction, Dangerous Driving, Bad Speelling. Who You Gonna Call? |
| I doubt that the service department will concern themselves with the fact that the MD wasn't the original radio on your car. It would be way too much work for them to check the spec on every MINI and BMW that they service. In addition if it is a recurring fault within the period of warranty, they can't refuse to fix it after the 3 year cutoff. Not sure if this will help you Linden, but I have aftermarket SatNav in my MPV and I notice that the CD-ROM unit doesn't switch off for about a minute after withdrawing the key from the ignition. Also there's a flashing light on the CD-ROM unit that flashes so I presume that it doesn't switch off fully and enters a standby mode. There is just one moon and one golden sun; And a smile mean friendship to ev'ryone; Through the mountains divide, and the oceans are wide; It's a small world after all. |
| Flat Battery | Pglenning | First Generation Faults & Fixes | 77 | Jul 25th, 2006 10:26 AM |
| Flat Battery. Please help | garby | First Generation Faults & Fixes | 7 | Jun 12th, 2006 11:24 AM |
| Flat Battery | ged1mcguirk | First Generation MINI Cooper S | 2 | Feb 27th, 2006 06:55 AM |
| Cooper S Flat Battery!! | jasonfields007 | First Generation MINI Cooper S | 3 | Feb 1st, 2006 06:04 PM |
| Flat Battery | spanky2k | First Generation Faults & Fixes | 10 | Apr 13th, 2002 04:44 PM |
