| well, ok.. it was a sunny day, it was clear and cold. The neighborhood children were waiting for the school bus with their parents standing nearby. All I could find on the radio was stupid dj chatter... I did notice that a neighbor I had seen chopping wood in his front yard had gotten quite a bit done. And my new neighbors across the street had put out what must be a 20 foot long row of empty boxes and packing materials.... |
| I've noticed the same thing. When the temp is less than 25-30 degrees F, I get a whistle between 2500 and 3500 rpm just after startup for a few blocks, then it goes away. I'm guessing it's the serpentine belt tensioner bearing or the alternator or something similar from the sound of it. I'm going to mention it to the dealer when it goes in for the first oil change in about a month. Anyone else??? ![]() |
| Cristo, thank you for responding! It's just really helpful to hear somebody else has a similar issue.. It's been in the 30s (F) here, and I've heard it 2 times today, first thing in the morning & again leaving work. The second time I noticed it I was backing up, so it happens regardless of direction, but much less noticeable on the back up. It seems to be coming from the central front area of the car. Last edited by BartMack; Feb 28th, 2004 at 11:51 AM. |
| actually, my noise does vary directly with rpms....starts above 2500 and goes up in pitch until before 3500 when it fades and dissapears. also, I can reproduce it by revving at a standstill in neutral or while moving. sounds like vhrrrr (kind of like when you whistle and hum at the same time). Haven't been able to get someone out to listen while the pedal is depressed yet to localize it, and it dissapears after minimal warming up, so extended tests aren't possible. ![]() |
| I tried revving it in the driveway and it did it at a standstill (right between 2500 and 3500 like you said) I had earlier thought that it was related to the motion of the car, but apparently not.. Last edited by BartMack; Feb 28th, 2004 at 11:55 AM. |
| I'm noticing this more this winter. It's a sharp whistle ("vrreee"... raises in pitch as the rev's increase) when revving the car (still or moving) from about 2-2.5K, and then again from 3.5-4K (although the pitch is in the same range for both rpm ranges). I initially thought it might be a bearing (idle tensioner, alternator, etc.), but now, I'm thinking it may be a valve in the vacuum system that isn't fully closed when it's really cold out. It goes away quickly when the car warms up, and I don't often have a ready accomplice to work the gas pedal to localize it. Anyone else have this or figure it out? I'm guessing the fuel tank vent valve or something similar so far. ![]() Last edited by cristo; Jan 23rd, 2005 at 01:27 PM. |
| It's the MINI version of WOOOOHOOOOOOOO!!!!, or his excitement of getting out for another drive. My BMW had a short whistling sound on some mornings, usually cold ones, when I would first drive off, then it would disappear. So, I am suspecting it is not a defect or fault. ***BMW-AG Rocks!!!*** Portsmouth FC Can Thank Sunderland...What a Farce!!! |
| Whistling Sound Revealed! I have a similar sound, and after some investigating, I think I have successfully traced it. When I start the car (04 MCS) and it has been sitting in the cold (seems like anything below about 40 degrees), I get the same whistling/squeaking sound when I rev the engine. The whistle/squeak appear when reving up or when blipping the throttle and then releasing. I traced my sound to a slipping supercharger belt. For whatever reason, when the engine is first started and cold, the belt slips if you rev the engine. As soon as the engine begins to warm up, the slippage goes away. I attributte this to not only cold weather, but also my 15% ALTA reduction pulley and its install. Since the pulley is 15% smaller in diameter it does create aditional slack in the belt. But the stock belt tensioner is more than capable of picking up this slack (unless you get a 19% reduction pulley, but that is a whole different can of worms). Where I think my real problem came in is that we used some lubricating spray (graphite based) while removing the pulley (it was stuck on there good!), and I think the lubricant is still causing a little slippage of the belt until it gets warm. My proof of this came after I took the time to use a de-greasing product a few weeks ago - applied, let it sit and then rinsed thoroughly. The squeak went away for a few weeks but has slowly started to return. I am hoping to do another round of de-greasing later this week. Hopefully this will take care of it for good. Anyway, hope this helps! |
| no, it can't be the supercharger belt , because I had the whistle on my 03 MC (no supercharger). It only happened on cold mornings for the first 2 -3 minutes until the engine warmed up. I also had belt screech which would happen later in the day on startup, like when I was going to lunch or going home. Additionally, I had a third symptom- periodic rough idle drop to the point of shuddering, which could happen at any time, but almost always happened onthe first take off on a cold start. I had it in 2-3 times for these, but never a solution, then I traded for an 05 S. |
| yeah I agree, I always thought it sounded like a vacuum system valve too, but the MINI techs told me there was not any intake valve to even make such a noise... but then I've discovered they don't ever really listen to me anyway, so who knows |
| Flutter/Warble Noise Under Hard Acceleration | Gavin1 | First Generation Faults & Fixes | 2 | Apr 22nd, 2005 11:18 PM |
| Not very good acceleration when cold! | Pinball | General Discussion | 23 | Jan 28th, 2005 05:40 PM |
| Groaning noise on acceleration when cold? | oldskoolflash | First Generation Faults & Fixes | 4 | Jan 22nd, 2005 06:01 PM |
| Wind noise whistle | moonshine | First Generation Faults & Fixes | 4 | Feb 24th, 2004 02:27 PM |
| FFFFFFFFFFFFFFFFT acceleration noise. | GMINI | First Generation Faults & Fixes | 14 | Dec 28th, 2002 08:35 AM |
