Very stiff change - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 1st, 2004, 02:19 PM
Grings's Avatar
Local Time: 04:40 PM
United Kingdom View Grings's Solid Black & Body Color 1st Gen MINI One Diesel Profile
Very stiff change
I did a search on this before I posted so no flaming please
This morning (after yesterdays Chilterns run), I got in the car turned on the ignition, put the clutch down (as I always do before starting up) and I couldn't get the car out of second. Eventually after much pushing it did go back in to neutral, but it was really stiff to engage. It felt almost like the gearbox was full of treacle.
I moved it around between gears and it started to get better, then after starting the engine and driving off it was fine without about 10 minutes.
Surely this can't be due to the oil becoming more viscous in cold temperatures (it was reading -3C this morning)? Anyone else experienced this?
Old Mar 1st, 2004, 04:04 PM
Ezzer's Avatar
Switzerland View Ezzer's Pure Silver & Black 1st Gen MINI Cooper Profile
My gearbox in my coop squeeks thru 1,3,5th gear until very warm and it is a little bit reluctant most of the time. But just to let you know, it cannot be the -3 temp, I went through -17.5C 2 days ago! And the car frequently sits through I imagine -5 in the evenings. No probs.
Old Mar 2nd, 2004, 12:41 AM
obehave's Avatar
Mini Mod
Local Time: 10:40 AM
There's also the frozen shift cable problem that seems to mainly be here in the States but yours is the second such I've read about in your neck 0' the woods.
Old Mar 2nd, 2004, 12:07 PM
Grings's Avatar
Max - don't think is was anything to do with leaving it in gear - I park on a totally flat surface at night. I only leave it in gear through habit. In terms of checking oil, the last time I cheked the engine oil was on Saturday. I don't ever check the gearbox oil - can you? I am of course assuming that our mini's are not like old mini's and do not share oil.
Like I described above, it did not just suddenly go away, it was like stirring ice cream, very diffiuclt to begin with, but gradually easier until it was fine.
It was OK this morning so maybe a one off?????
Old Mar 2nd, 2004, 12:21 PM
Grings's Avatar
Quote: Originally Posted by Max
The engine and tranny share the same oil mate
Well you learn something new every day
Racer's Avatar
Blast from the past !
Send a message via ICQ to Racer
Local Time: 03:40 PM
View Racer's Kawasaki Green & White 1st Gen MINI Cooper Profile
I hope not - sarcasm or typing mistake ?
Old Mar 2nd, 2004, 01:12 PM
obehave's Avatar
Mini Mod
Well I dunno then Simon - hopefully a one off.
catcha
Then the winshield washer and radiator do too ...right???
Old Mar 2nd, 2004, 06:05 PM
J1JPE's Avatar
United Kingdom Male View J1JPE's Sparkling Silver & Black 2nd Gen MINI Cooper Profile View J1JPE's Classified Ads
New Gearbox oil
Hi folks, according to somone 'in the trade' who has an S; he found changing the oil to a performance one fixed the probs ... goes to find note of type ....Millers Motorsport Gearbox oil CRX 75W 90 you need 1.5 ltrs so 2x1ltr bottles .... plus ramps/stands etc to drain and refill - plug can be re-used
self same persons company sell it and is listed on here
Cool ? [no more clues]
if anyone has changed the oil for better (or worse) pls let us know
Stiff Neck mhed58 General Discussion 7 May 21st, 2007 12:38 AM
stiff ride g0t MiNi? First Generation Faults & Fixes 2 Dec 22nd, 2006 08:14 AM
Stiff neck? annabean General Discussion 12 Aug 4th, 2003 07:02 AM
