How do you know xenon self leveling works? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 15th, 2004, 09:38 PM
Apial's Avatar
Local Time: 12:40 AM
United Kingdom Male View Apial's Lightning Blue & Silver 2nd Gen MINI Cooper Diesel Clubman Profile
People often recount how the xenon self leveling feature works in a noticeable way. I can't say I have noticed them budge whilst on the road. I did a test. Whilst parked and aimed at a wall, I let the clutch out slowly so that the nose of the car rose upwards. I expected the xenons to level downwards, but nothing happened, the beams just aimed higher up the wall.
I also tried pushing the front of the car down, but nothing happened again.
Has the system got a fault? How can you tell its working correctly?
Old Mar 15th, 2004, 09:58 PM
Paul's Avatar
MINI2 No.1
Local Time: 01:40 AM
England Male
I suppose you could try using a jack to raise the front? Do they adjust up and down when you switch the car on? I think the pattern is "up - down - level".
Old Mar 15th, 2004, 10:07 PM
BartMack's Avatar
#1647 of 1960
Send a message via AIM to BartMack Send a message via Yahoo to BartMack
Local Time: 08:40 PM
United States Male
of course this touches on that age-old question:
If a xenon levels itself in a forest.....
Old Mar 15th, 2004, 10:47 PM
Local Time: 07:40 PM
United States View elbee's Pure Silver & Body Color 1st Gen MINI Cooper S Profile
When I turn mine on they go up-down-level. I don't think that they move while driving but I have noticed some twitching whiling driving around; may have just been the road. I couldn't imagine that they are supposed to move while driving as they would rarely ever be pointing in the right direction. Does anyone know why they 'self-level'?
Old Mar 15th, 2004, 10:59 PM
NEMINI.org
United States View NEMINI's Silk Green & Black 1st Gen MINI Cooper Profile
More weight in the car, specifically the boot or back seats would cause the backend to be lower therefore causing the aim to be too high. In the US inorder to have Xenon lights it is mandatory to have self levelers to reduce the chance of blinding oncoming traffic.
Old Mar 15th, 2004, 11:07 PM
AMT's Avatar
AMT
Scotland View AMT's British Racing Green & White 1st Gen MINI Cooper Profile
Mine are always twitching up and down. It's very noticeable, especially when parked behind someone at traffic lights-- they'll level up after around 3 seconds.
When i turn mine on, they light when down, then level up. That's it.
Auto self-leveling on Xenon's is mandatory in UK as well.
I should also add (as posted elsewhere) that I believe my xenon's to be aimed a bit too low. So maybe this is why mine are more active than usual?
Old Mar 16th, 2004, 03:43 AM
gtshnzr's Avatar
Send a message via AIM to gtshnzr
United States View gtshnzr's Solid Black & Body Color 1st Gen MINI Cooper S Profile
Agreed. Upon start-up they automatically level while backing out of the garage (really sooner, almost instantaneously) and you can see it on the back wall, the up and down motion.
Early is on time; On time is late.
Old Mar 16th, 2004, 08:20 AM
Paul's Avatar
MINI2 No.1
England Male
When in motion you should also be able to see them moving, as stated above, although sometimes it's harder to spot than others.
Old Mar 16th, 2004, 11:24 AM
Apial's Avatar
So if you do my test it will not show you? Releasing the clutch gradually with the handbrake on causes the bonnet to rise and the boot to dip. The xenons should correct this upward tilt and keep the aim at the same spot on the wall, right?
Old Mar 16th, 2004, 02:40 PM
United States View dmholmes's Indi Blue & White 1st Gen MINI Cooper Profile
Not sure about the "mandatory" in the US statement. My wife's CL Type S has xenons and I've never seen them self level like in the Mini. Come to think of it my friend's RX-8 doesn't either. The Mini ones, however, are quite "busy" and noticeable even while driving.
I've also seen statements that headlight washers were also required for xenon's but again, the previous two cars mentioned don't have them. Not looking to start an argument and I am quite open to being corrected.
2004 Winning Blue Mazda RX-8
Old Mar 16th, 2004, 08:55 PM
scooterboy's Avatar
Local Time: 09:40 PM
United States View scooterboy's Indi Blue & Black 1st Gen MINI Cooper Profile
While driving, the headlights will self-level periodically (every 30 seconds or so?), as well as whenever there's a rapid speed change (quick braking, quick accelerating). I often see mine shift up or down when braking at or leaving a stop light.
Old Mar 16th, 2004, 09:01 PM
planeguy's Avatar
IF you dont see them move when you turn them on, then I would guess that they are defective. You can't miss the adjustment when you turn them on
Old Mar 16th, 2004, 09:15 PM
Apial's Avatar
They do adjust when switched on, they aim down then move back up again. And thats where they stay put!
Old Mar 16th, 2004, 09:19 PM
scooterboy's Avatar
You will not see them move if you let the clutch out gradually. They react to sudden speed changes, not gradual ones. If you brake quickly at a stoplight behind another car, you should see the reflection of your lights shift once you stop. (do it carefully though!)
  #15 (permalink)
Old Mar 16th, 2004, 10:26 PM
GadgetGav's Avatar
gadgetmeister
United Nations View GadgetGav's Dark Silver & Black 1st Gen MINI Cooper S Profile View GadgetGav's Classified Ads
Mine twitch up and down when I'm pulled up behind someone in traffic... To go to the original question of HOW they work, there is some kind of sensor in the slotted area in the headlight unit (where it says Xenon) that 'reads' the patten on the road. I think it gets fooled when sitting in traffic by the highly reflective surface of the car in front's paint or number plate. Don't know if the test described will cause them to level... Try moving a white piece of card or something like that in front of a headlight and see if you can fool it into moving.
Religion is like a huge dog. If it's yours it's very friendly and comforting, but it scares the heck out of everyone else.
Headlight Leveling? supa-dupa-cooper First Generation MINI Exterior 6 Jan 24th, 2008 09:04 PM
Are the MINI Xenon headlights self leveling like the BMW lights? jrozario General Discussion 9 Jun 4th, 2006 11:02 PM
Xenon auto leveling / high beam allignment Pamlico First Generation Faults & Fixes 7 May 20th, 2005 05:49 PM
Xenon Leveling??? MINIGT50 First Generation Faults & Fixes 8 Feb 15th, 2004 10:06 AM
Xenon headlights self-leveling feature BartMack General Discussion 25 Nov 21st, 2003 12:03 PM
