| Check carefully your oil levels folks; apparently I didn't some time back & now I have a busted-off dipstick stuck in the tube. At the 30,000+ mile check last October (I've just rung up 43K!) I'd noticed a kink in that fiberglass thing BMW's "engineered" & asked for a replacement, though had no reason to get back to the dealer to pick it up after it arrived.... I went to check the oil level last week & found the kink served as a failure point. I was left holding the 'stick handle & about 6 inches of dipstick, the meaningful part remained behind. Dealer syays the oil pan has to come off to get the broken end out properly. |
| >>>Dealer syays the oil pan has to come off to get the broken end out properly.<<< That, unfortunately might be the only way to get it out. There is a procedure I've used that has worked on occasion in the past, but I hesitate to recommend it. If they're going to do it under warranty let them. If not and you want to try this PM me and I'll fill you in. -- '03 S B/W |
| They didn't have a pan gasket in stock, or the replacement 'stick either, so it'll be a couple more days in the shop. All I can hope for is that they get the pan on right & it doesn't end up leaking, and I don't kink the replacement 'stick again sometime after the warranty expires. At the rate I rack up miles, that'll be sometime this coming July.... |
| Checking the oil - dipstick is useless... | batfink | First Generation MINI Tuning | 30 | May 2nd, 2006 03:59 PM |
| Oil DipStick Sticking solution | GoMiniGo | General Discussion | 6 | Sep 20th, 2004 02:14 PM |
| Oil dipstick | 118 | Maintenance & MINI Care | 5 | Aug 24th, 2004 12:27 PM |
| S Oil Dipstick | JG.26 | First Generation MINI Cooper S | 17 | Apr 16th, 2004 03:26 PM |
| Oil dipstick redesign? | PigLick | General Discussion | 28 | Mar 24th, 2003 11:30 PM |
