Do your washer jets get blocked easily? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 29th, 2004, 05:10 PM
Mega Mini's Avatar
Proud New Mini Owner
Local Time: 12:15 PM
United Kingdom View Mega Mini's Indi Blue & White 1st Gen MINI Cooper Profile
Question Do your washer jets get blocked easily?
When I used the washer jets mounted on the bonnet today they were all blocked except for one. I am thinking of putting a pin down the jets to unblock them but don't want to widen the holes so they loose all pressure. Has anyone else had this and what have you done? BTW, I use premixed Halfords screen wash and now the jets have a blue tint to them.
Old Mar 29th, 2004, 06:40 PM
Paul's Avatar
MINI2 No.1
Local Time: 11:15 AM
England Male
No problems like that here.
Old Mar 29th, 2004, 06:42 PM
ButtonIt's Avatar
www.totalmini*****
Send a message via MSN to ButtonIt
England Male View ButtonIt's Hyper Blue & Body Color 1st Gen MINI Cooper S Profile View ButtonIt's Classified Ads
Hard water area here, I get blocked jects all the time. Use a pin, but be careful.
Also premix washer fluid is horrible, it left powdery deposits all down my car I always use mix your own stuff now, and keep a large bottle that I prepared earlier in the boot.
Old Mar 29th, 2004, 06:53 PM
dcfkan's Avatar
In exile, down SOUTH!
United Kingdom Female View dcfkan's Chili Red & Lime Green 1st Gen MINI Cooper Profile
Nope, and I use normal tap water to mix mine up, use them a lot too
The only times they failed to work occured during extreme cold spells when the pipes were frozen solid
DK :apple:
Old Mar 29th, 2004, 07:07 PM
Irlmin's Avatar
Peoples Republic Of Cork
Send a message via Skype™ to Irlmin
Ireland Male View Irlmin's Chili Red & Black 2nd Gen MINI Cooper Profile View Irlmin's Classified Ads
Ireland
I have no problem with Screen washers, however rear one has blocked on several occasions ,use a pin it should work .
Gerard
Old Mar 29th, 2004, 07:37 PM
Mega Mini's Avatar
I am going to go gingerly at it with a pin tomorrow. I did a searchand found the problem had been reported before and that pins are the best tool for the job. The problem is worst in hard water areas. I live in Bath which has very hard water so I especially bought the pre mixed formula but it is since putting that in that the problem started. Will let you know how I get on with it but any more suggestions or experiences would be welcome.
Old Mar 30th, 2004, 12:22 AM
RickB's Avatar
United States View RickB's Dark Silver & Black 1st Gen MINI Cooper S Profile
In a year-and-a-half of ownership, I've had to unplug mine twice. A pin worked fine.
Old Mar 30th, 2004, 05:05 AM
Bilbo Baggins's Avatar
Local Time: 06:15 AM
United States Male View Bilbo Baggins's Space Blue & Silver 1st Gen MINI Cooper S Profile
I have a August '02 MCS and have never had a clogged jet.
'06 MCS SB/S R84s(BFG Traction T/A V, summer), R81s(Nokian Haakapiilatta 2, winter)
'02 MCS DS/W (retired)
Old Mar 30th, 2004, 06:21 AM
scooperman_uk's Avatar
almost 59k
United Kingdom View scooperman_uk's Solid Black & Body Color 1st Gen MINI Cooper S Profile
the jets have frozen loads of time. blocked a few times. ive used a pin and some anti freeze to loosen the junk in them.
Old Mar 30th, 2004, 06:44 AM
6X therapist
View Goonery's Classified Ads
No Just froze up
Old Mar 30th, 2004, 10:42 PM
SteveM3's Avatar
Most washer jet systems have a little filter in it. If your jets continue being
a problem take it to the dealer to check. No idea where this filter is in a MINI
but it is often next to the washer bottle so it may be more palaver than normal
to check in a MINI. If the worst comes to the worst Halfords sell aftermarket
versions of the filter, you can cut your pipes and stick this in line.
Old Sep 23rd, 2004, 09:20 PM
RickB's Avatar
Where is the washer jet for the rear window? My dealer had me looking on/inside the wiper arm, but I can't find anything in there that looks like a jet. There is a little nub on top, back toward the hub end, but I can't tell if that's it, either; I'm getting no washer action at the rear, despite a full tank and lots of pump noise.
"I'll shoot for the queen, and you for, well, whomever."
Old Sep 26th, 2004, 11:11 AM
Paul's Avatar
MINI2 No.1
England Male
It's on the wiper, on the top "side" of the base area. On '05 model years it's more obvious, but not as effective.
Old Sep 26th, 2004, 11:19 AM
Rayman's Avatar
"Buying and selling"
Send a message via MSN to Rayman
United Kingdom View Rayman's Indi Blue & White 1st Gen MINI Cooper Profile
Had this problem too, also live in hard water area, i also feel that waxing my car near the washers caused me problems too, most certainly a build up of hard water and wax. Pin didnt help me much!
2001 cooper (sold)
1995 Supra RZ-S TT auto in white.
Washer jets Billy Smart First Generation MINI Exterior 8 Feb 23rd, 2009 09:35 PM
Washer Jets ps_minics First Generation MINI Exterior 3 May 24th, 2006 04:37 PM
Headlamp Washer Blocked!! Burgy First Generation MINI Exterior 9 Feb 2nd, 2006 12:17 AM
blocked rear washer Haggi First Generation Faults & Fixes 11 Jan 16th, 2006 04:35 PM
Washer Jets smiffy First Generation Faults & Fixes 3 Jan 12th, 2003 10:12 PM
