Vibration problem - front corner - not wheels! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Apr 20th, 2004, 10:20 AM
Evista's Avatar
Local Time: 11:06 AM
England Vibration problem - front corner - not wheels!
Hi,
2002 MCS
I have a vibration from the drivers side (UK) front corner. You cant really feel the vibration, it is more of a rubbing noise. Happens from 40MPH plus
Took it to local dealer yesterday who had a brief look and couldnt find anything with the wheel or bearings so put it down to the run flats being at the legal limit. So I had the front tyres replaced and balanced this morning as they were on the way out but that hasnt stopped it. I also had the fronts swapped over to see if the noise would transfer and it didnt.
I have also noticed that there is a creaking sound from the top of the steering column which I initially thought was something superficial until I read the threads on here about problems with the steering column and others about the rack - is the sound I am hearing symptomatic of teh steering problems or are there any other reasons for this?
IS THIS A PROBLEM? smoke from front scoop kee1983 First Generation MINI Cooper S 25 Mar 20th, 2007 11:46 AM
Front Seat-Back Problem Flower Maintenance & MINI Care 3 Nov 21st, 2006 05:33 PM
Vibration problem HObzy First Generation Faults & Fixes 20 May 3rd, 2006 09:32 PM
Front visual problem? NobbyS First Generation Faults & Fixes 5 Oct 17th, 2005 03:25 PM
Severe tire vibration, Aftermarket Wheels haroldchrismeyer Wheels, Tyres & Brakes 1 Jan 24th, 2005 02:10 PM
