knocking/clunking noise?????????? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Apr 29th, 2004, 10:16 AM
ASTON's Avatar
A mini is a way of life.
Send a message via MSN to ASTON
Local Time: 12:06 PM
Wales Male View ASTON's Pepper White & Black 2nd Gen MINI Cooper Diesel Profile View ASTON's Classified Ads
Wales knocking/clunking noise??????????
when my cooper s reaches the normal running temp,i can hear a knocking/bang from the n/s under the car.i can hear it on tick over.if i turn the engine off,i can still hear it every 10 or 20 seconds till the car cools down.it sounds like a hot exhaust cooling down,but its not.
any one else had this problem??? is this nornal??? ive only had the car a week
regards
aston
Old Apr 29th, 2004, 07:42 PM
DrJ's Avatar
DrJ
DrJ
Wales
not sure but all I can tell you is that mine doesn't do it.
[ MCS Works, Eibachs, EBC Greenstuff Discs and Pads, Whalen Shift Machine, Toyo Proxes T1-R's Hold on Tight
Old Apr 29th, 2004, 11:03 PM
Rich'sFroggy's Avatar
Local Time: 07:06 AM
Yes. Mine does it too. Noticed it about 2 days after I took delivery. I'm sure there are tons of posts about it here on Mini2 if you do a search.
Funny thing however..........I never bothered to look into it. Don't know why, but I've always accepted it as something the car just does. It is somewhat annoying, and I should probably try to get it corrected.
It's definetly a heat thing. Very strange.
Old Apr 30th, 2004, 02:15 AM
flatsix02's Avatar
Hulk.
Send a message via AIM to flatsix02
Local Time: 06:06 AM
United States View flatsix02's British Racing Green & Body Color 1st Gen MINI Cooper S Profile
Is it a loud like, knocking sound that comes from under the car after driving? If so, its because the car is still new and it's something to do with the exhaust. Mine did it for a while, and i just passed the 4500 mile mark and it doesnt seem to knock really loud anymore.
Hope this helps ya,
-scott
Old Apr 30th, 2004, 09:53 AM
My MCS Works!... it does!
Local Time: 11:06 AM
United Kingdom View PastyMuncher's British Racing Green & Black 1st Gen MINI Cooper S Profile
My MCS JCW always makes quite a lot of noise while cooling down. I don't know what the standard MCS looks like underneath, but around my exhaust system are a whole load of pressed alloy heat shields- far more than I have seen under any other car I have owned. I have simply assumed that, based on the size of them, these heat shields move considerably when cooling down. Any movement in these big metal sheets is bound to make quite a noise.
I would be surprised if it is any problem at all. Maybe just give the dealer a call to put your mind at rest?
BTW mine is 14 months old with 8.5k miles on it..... however, it ahs only had the JCW on for 8 months.
Old Apr 30th, 2004, 10:29 AM
ASTON's Avatar
Wales
thanks for all your replies. i am going to my dealers today,just to put my mind at rest.
regards
aston
clunking noise from the rear Esc8p2NeverLand First Generation Faults & Fixes 6 Mar 11th, 2006 11:56 AM
clunking noise from rear steve1968 First Generation Faults & Fixes 3 Jan 12th, 2005 07:23 PM
Clunking noise from underneath! SMARTIE First Generation Faults & Fixes 3 Dec 13th, 2004 12:38 PM
Clunking, knocking sound jgpmini First Generation Faults & Fixes 7 Jan 14th, 2004 06:32 AM
Clunking Noise Bonnie Scotland First Generation Faults & Fixes 6 Nov 17th, 2002 04:05 AM
