| I ordered some of that langka stuff and it is great for removing blobs of paint when touching up chips. I think I just ran a search for it on the web and ordered it from some paint suppliers. "Do try to keep up Nigel!" |
| Won't T-cut do the job? Paint from a paint stick is usually pretty soft compared to the original or a respray that needs baking and I assume as you saw you put too much on you didn't clearcoat it. ![]() Some people are like a Slinky ........ not really good for anything, but you still can't help but smile when you shove them down the stairs |
| hiya michelle, is this blod a result of a touch up on a scratch? if so i reckon you best bet is to use t-cut, ever so gently, dont go over board, just rubit and check it , and rub it till the blob dissapears, i did this on my past vauxhall corsa to good effect. i wouldnt pay 148 quid to cover a scratch up i can tell you !!! good luck :-) |
| HELP!! Mini paint stick! | vortexni | Maintenance & MINI Care | 3 | Jul 8th, 2007 05:27 PM |
| So where did u stick it ??? | MiniSMan | General Discussion | 13 | Apr 29th, 2006 06:04 PM |
| mini paint stick help. | MaTTy_P | Maintenance & MINI Care | 3 | Sep 30th, 2004 11:48 AM |
| Is metallic paint better than solid paint? | fs-mini | First Generation MINI Exterior | 6 | Jul 15th, 2004 01:00 PM |
| Solid Color Paint or Mettalic Paint | emdionisi0 | General Discussion | 22 | Jul 16th, 2002 02:44 PM |
