Smelly Air-Con - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jun 9th, 2004, 05:09 PM
appmacguy's Avatar
Send a message via MSN to appmacguy
Local Time: 04:53 AM
United-Kingdom Smelly Air-Con
Noticed when using the blowers in my car, mainly at lower temperatures theres a fusty smell as if the filter or something is damp. My mini has climate control and wondered if anyone else has this or can help me out.
Thanks in advance!
Paul
57 Mini Cooper, Astro Black.
Old Jun 9th, 2004, 05:18 PM
dcfkan's Avatar
In exile, down SOUTH!
United Kingdom Female View dcfkan's Chili Red & Lime Green 1st Gen MINI Cooper Profile
I believe that is normal as I have not come across any air con that does not smell damp immediately after being turned on.
I have climate control too, and leave mine set to 16 deg C permanently
DK :apple:
Old Jun 9th, 2004, 05:22 PM
devilsushi2000's Avatar
Send a message via MSN to devilsushi2000
England View devilsushi2000's Classified Ads
I have the same problem, i asked them to rectify it at the service and when i got my car back, the aircon smelt great! Only for a day though then it smelled horrible again. It only smells damp when i first turn it on and only when the air is coming out of the front vents.
Old Jun 9th, 2004, 06:13 PM
andyupnorth's Avatar
Do you smoke in the car? If you smoke with the a/c on and especially if you use the recirc button, the stale smoke gets in the system and it's impossible to get rid of that horrible smell without major expense.
"Do try to keep up Nigel!"
Old Jun 9th, 2004, 06:19 PM
piner's Avatar
Local Time: 03:53 AM
United Kingdom Male View piner's Hyper Blue & White 1st Gen MINI Cooper S Profile
Read something in auto express today about a product (Comma Air Conditioning clearner)which you spray onto your evaporator which kills bacteria and fungi. Works for upto 8,000 miles. could stop the smell
Old Jun 9th, 2004, 06:25 PM
SA-Cooper's Avatar
Local Time: 05:53 AM
South Africa
My 2 pennies worth - I had a similiar problem in my car, couldn't trace what the cause were. I took the car in for it's first service, and they replaced the filter unit for the aircon. The old filter was dirty as hell and had an aweful smell - maybe u should ask your dealership to have a look at the filter unit, and replace if neccesary.
Leccy_Blue's Avatar
Just got my car back from the dealer today to have this problem sorted. They did a treatment on it, which apparantly isn't covered by warranty that cost me £10. It seems to have solved the problem though
LB.
Old Jun 9th, 2004, 07:08 PM
I think im going to try the Comma Air Conditioning cleaner. Ill check halfords next time i go there and tell you how i get on
Old Jun 9th, 2004, 07:49 PM
jonkudla's Avatar
Local Time: 07:53 PM
Condensation can form when the A/C is turned off and this can provide a fertile growing area for smelly fungus.
This happened somewhat frequently on my last car but I found it went away if I made a habit of turning the A/C off and running the fan to high, for a minute or two, once I start to get near my destination. Blowing non-conditioned air helps to evaporate any leftover moisture.
Old Jun 9th, 2004, 08:01 PM
racer-x's Avatar
Local Time: 08:53 PM
United States View racer-x's Dark Silver & Black 1st Gen MINI Cooper S Profile View racer-x's MINI Features Album
I have this problem, I thought it was me FEET!
Old Jun 9th, 2004, 10:25 PM
Babaza's Avatar
Air-Conditioning boffins reckon you should turn off Air-Con 10 minutes before you end your journey with only the fan on.
Old Jun 10th, 2004, 05:09 PM
alicantecooper's Avatar
Newbie no more!
Spain
We do that all the time here. If not you can never get the damp smell away. Never had this problem in the UK but now we use the air con lots I just turn it off a few minutes before parking up! I reckon it keeps the smell to a minimum even though when you first turn it on it still smells damp for a few seconds.
Old Jun 21st, 2004, 02:55 PM
Found the comma air conditioning cleaner in halfords today. You simply put the air con on re circulate press the button on the cannister (in the rear footwell with the front seat back), close the door and leave it for ten minutes and the aircon is clean. Gets rid of moulds and fungi etc. No more smellyness! Would reccomend it!
Old Jun 22nd, 2004, 01:13 PM
J1JPE's Avatar
United Kingdom Male View J1JPE's Sparkling Silver & Black 2nd Gen MINI Cooper Profile View J1JPE's Classified Ads
got the dealer to clean & refresh mine for nowt the other day while it was in having it's rattles sorted; it's been cold & wet ever since so havent been able to test it .... coincidence ?
  #15 (permalink)
Old Jun 22nd, 2004, 03:57 PM
I got them to do that after the last service and it smelled fine for about 2 days then it was bad again!
This comma air thing works a treat though
Smelly air! lilpee69er First Generation MINI Tuning 3 Sep 5th, 2007 11:43 AM
Smelly Air LucyD First Generation Interior & Ice 35 Aug 7th, 2006 09:00 PM
Smelly Cold Air DoningtonPhil First Generation Faults & Fixes 3 Aug 5th, 2005 09:59 PM
Air-Con / Auto Air-Con / Climate control ??? fitzsimonss First Generation MINI One 13 Apr 19th, 2004 10:44 PM
