Drivers side window opening - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Aug 17th, 2004, 04:10 PM
Local Time: 11:08 AM
Wales
Wales Drivers side window opening
Hi All......can someone help......!!!
My drivers side window keeps on opening...i have been to my dealer and he said that it is part of the comfort opening which you activate off the key ( easy access opening ).
The problem that i am having is that i am activating the window somehow ....does anyone know the combination to use as my dealer is baffled
Comfort opening is activated by holding down the open button on your key but how is easy access opening activated.......
Please HELP...!!!!!
RYL (pinks sister)
MOD
RYL
Old Aug 17th, 2004, 04:42 PM
Paul's Avatar
MINI2 No.1
England Male
"Easy access opening"?! Any kind of opening you do via remote or the key opens both windows...
Is JUST your drivers side window opening, and when is this happening (are you in the car, out of the car, near the car....)?
Old Aug 17th, 2004, 06:36 PM
Wales
Wales
Cheers for the replies.....
It only happens when i go to open the drivers door..... the window goes all the way down...not like in comfort opening when the windows go down in stages......!!! the whole thing is baffling me.....i think my only option will be to get my dealer to clear the memory and re program my key.....
RYL
MOD
RYL
HarryHBMCC's Avatar
Local Time: 06:08 AM
Canada Male View HarryHBMCC's Laser Blue & Black 2nd Gen MINI Cooper S Convertible Profile
Just the driver's door? Easy access opening I've not heard of. My car had a problem with the BCI (body computer interface) and the door actuator that had the window opening, closing, unlocking the door etc. Search faults and fixes for 'christine' (think Stephen King's car horror) and you'll see similar.
That said, I did have it unlock a few times by pressing the key button by accident in my pants so try leaving the key fob on a desk or dresser and see if it happens there or just while in a pants pocket. If just in a pants pocket then don't wear such tight trousers ;-)
Harry
Old Aug 17th, 2004, 07:24 PM
Paul's Avatar
MINI2 No.1
England Male
RYL
MOD
So you unlock it (via the remote), and that's OK, it's actually when you "pull the trigger" on the door the window just unwinds all the way? Sounds like eithe the computer's gone nuts, or something is wrong with the window mechanism. Of course the window should drop a fraction, then raise again when you close it so it misses the "door frame", it sounds like it's just not stopping.
Old Aug 18th, 2004, 10:59 AM
Wales
Wales
It happened again tis morning...but i can't figure out the combination....i open the car via the remote key....then i opened the passenger door to put my bag in the car.....then i opened my drivers door and BINGO....the window went all the way down......only option is i think to clear the keys memory and install agian...
RYL
Old Sep 1st, 2004, 10:49 AM
Wales
Wales
Problem solved
open the drivers side door and press unlock twice.......
RYL
Old Jun 2nd, 2005, 06:24 AM
phil_wkl's Avatar
Local Time: 12:08 PM
England Male View phil_wkl's Cool Blue & Black 1st Gen MINI Cooper Convertible Profile
Is this meant to be a feature?
Drivers window opens on its own when opening the door.
Its happened a few times to me, but I'm pretty sure I'm not touching the remote, as I'm just getting out or into the car.
Drivers Side window not opening... eddycooper First Generation Faults & Fixes 3 Jun 15th, 2007 02:54 AM
HELP !!! rear window shot out drivers side... marioluigi First Generation MINI Exterior 1 Apr 10th, 2006 09:54 PM
Auto window down when opening the door... Muel First Generation Faults & Fixes 1 Nov 22nd, 2005 08:09 AM
Comfort opening breaks drivers window... Kodak General Discussion 9 Aug 30th, 2005 06:08 PM
Random window opening m111n1 First Generation Faults & Fixes 12 Jan 25th, 2004 01:53 PM
