| Cold Start I have a 2002 MINI Cooper S with approx. 3700 miles, here's the issue: At first start every morning I have to start the car twice - first attempt it doesn't quite start; switch it off then re-start and it runs fine and operates normally the rest of the day. Anyone else experienced this? Thanks |
| It is a common problem, do a search on here and you will find many similar complaints. Mine does the same thing, not all of the time but frequently. My dealer told me to put some mid-grade fuel in the tank instead of premium. When I tried this it seemed to lessen the problem. Now I alternate between mid-grade and premium fuel. Usually I do not have a problem. This is an on-going problem and MINI is aware of it. Motor on, Dudes and Dudettes!!! '06 MCS SB/S '02 MCS DS/W (retired) |
| Please do a search and you'll find several threads on this. Basically the engine software isn't happy with the summer formulation of our gas. Pretty much every single MCS in the Northeast is having this problem. Putting in a lower octane fuel seems to help, but your performance and gas mileage suffers. Several of us have tried several different brands of fuel, and that doesn't help at all. My own car has been having this problem since late April. I have given up hope of MINI coming out with a fix. By the time they finally have a fix available, we will be back to winter gas. |
| My 05 MCS--as well as about 4 others I know with 05's--have this cold-start problem as well. Jeez you'd think BMW would have a fix by now? It's almost like the car needs a manual choke or something.... But at 1800 miles this is my only issue--otherwise my car is rock-solid with excellent mpg (average 29-31.) I wonder if it's fuel formulations for emissions standards, ie ethanol/MTBE? Jimbo |
| My dealer is well aware of it. It is a software issue, and there is nothing the dealers can do about it. My car had V36 and now V39, and nothing helps. I asked the service manager what percentage of MCSs are experiencing this hard start issue, and he said "every single one of them." Once the gas formula goes back to winter gas formula, your car should be fine. |
If you hold the key in the start position for twice as long, will it start on the first try? This was an annoyance for me for a while. It never seemed to start as quickly as it should. But I've become used to running the starter for a little extra time and it seems to work ok. Probably hard on the battery. Warm starts are fine for me. |
| Tags: cold start, cold start problem |
| Won't start.......................NOT cold start issue | Rwatts4mini | First Generation Faults & Fixes | 2 | Nov 5th, 2011 01:16 PM |
| Cold Start RPM | Ronster | First Generation Faults & Fixes | 2 | Feb 20th, 2009 08:55 PM |
| Cold-start problem? | Robert In Denver | First Generation Faults & Fixes | 9 | Jul 8th, 2003 06:16 AM |
| Cold start problem....again!! | LuckyRVA | First Generation Faults & Fixes | 8 | Jun 17th, 2003 06:07 AM |
| Will not start period....NOT Cold Start Issue | Silly | First Generation Faults & Fixes | 31 | Aug 5th, 2002 02:35 PM |
