| I have the same problem too! Took it for a service six months ago and asked them to check it out. They said that its when the battery is a bit flat, and that its the gauges just resetting themselves. Try taking it for a long run and then try it, they should be fine. Hope this helps Paul |
| Your Battery almost expires Used to have this problem. And in the end it's the battery for sure. The noise is coming from the needles pulsates. Took it to the dealer and the car won't start in the hands of MINI tech. Change the battery and everything is the way they used to be MCS JCW Dark Silver/Black |
| Mine did this on Saturday morning, and the car hadn't been used since wednesday night....So the battery theory sounds most favourite...Started it again after washing it and it did not do it again, and started it this morning and it didn't do it either...Our MINIs just like talking to us and moaning at us, probably for leaving them in the cold!!! |
| The battery thing makes sense. It still does it occasionally but I've been using the car more often recently and its nowhere near as regular. The needles seem to bounce down against the stop for a few seconds, hence the noise. Not too fussed about getting it looked at - the car goes back in Jan to be swapped for an S. |
| Run Flat Tire Potential Problem | David Brown | Wheels, Tyres & Brakes | 1 | Apr 14th, 2007 06:15 AM |
| Has anyone received "Potential Problem" letter from Mini? | minime56 | General Discussion | 3 | Sep 30th, 2005 06:51 AM |
| Thule roof rack potential problem | phazer | First Generation MINI Exterior | 0 | Sep 2nd, 2005 02:59 PM |
| Wollastons - Potential Ticket Problem | SoggyCornFlakes | MINI in the Media | 5 | Sep 10th, 2003 08:08 AM |
| Potential problem smogging SuperTrapps | TonyB | First Generation MINI Tuning | 14 | Aug 19th, 2003 06:21 PM |
