Cooper S Rough Idle Possible Fix! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 16th, 2004, 11:13 PM
Dave&Stacy's Avatar
SCCA ClubRallyists
Local Time: 06:39 PM
United States View Dave&Stacy's Chili Red & White 1st Gen MINI Cooper S Profile
We took Molly up to Motorwerks MINI to have her CD player replaced under warranty. In addition, I wanted them to check out the "rough idle" condition we noticed a day or so before. This happened when we were parked at a gas station and just sitting there. It started to stumble between 500 and 700 rpm. I blipped the throttle and it stopped. Hadn't had an issue since.
So....
Jim the lead service tech. (and in our opinion probably the best and nicest MINI tech in the Midwest...possibly the world) started checking her out. We headed off the mall assuming we would have Molly back in an hour or two. We were a bit mistaken. They called us after 2 hours and had the shuttle pick us up from the mall. When we got back, they had a courtesy car waiting and took us back to Jim so he could explain what was up. When he ran a diagnostic test, he noticed that the overall fuel correction percentage (this isn't the correct term but I forget what is) was 7.6%. Another Cooper S he had tested earlier in the day was running 1.6%. Essentially this indicates that the engine is running in a lean condition and the computer is compesating by adding extra fuel. Anything under 10% will not throw a CEL, and over 10% will. But...he thought it was still too high. So he started to look for vacuum leaks. He found one in the intake tract between the throttle body and the supercharger. He wasn't sure if it was the gasket or the intake pipe itself so he wants to replace both. Unfortunately the parts won't be in til tomorrow so we went home MINI-less. However, he said this should take care of the rough idle issue.
Those of you experiencing the rough idle should have this looked at! I don't think this particular part of the intake tract was changed between pre-'05 and 2005. It's a relatively easy fix.
Anyway, so we're headed back on Saturday to pick Molly up. Good as new!
Oh, and Jim....if you're reading this...you rock!!!! You are the nicest, most helpful, and most knowledgable service tech we have ever met. Thanks for all the help!
-Dave & Stacy
"Sideways at 80 mph through the woods. Is there a more intense rush?"
- 2005 CR/W MCS, JCW Kit, Xenons, DSC, On-Board Comp., 3-spoke Multifunction, F/R Fogs, Extra 15" 7-hole Wheels for Rally Tires -
Old Sep 17th, 2004, 01:30 AM
I like MINIs I do
Send a message via MSN to abs0lutely
Local Time: 12:39 AM
United Kingdom View abs0lutely's Cool Blue & Dark Blue 1st Gen MINI Cooper S Convertible Profile
Thanks for that! Mine has also started to struggle a few times when idle.
Please let us know if this fixes the problem, as I'll probably get mine checked out too.
Old Sep 17th, 2004, 02:20 AM
obehave's Avatar
Mini Mod
Yup, me too.
Old Sep 18th, 2004, 02:35 PM
Bear's Avatar
United States View Bear's Dark Silver & Black 1st Gen MINI Cooper S Profile
United-States
Dave&Stacy
Your signature line indicates you have a JCW equipped Mini. Maybe this fault was a result of the kit being installed.
Bear
JCW - S1266
Old Sep 19th, 2004, 03:44 AM
I like MINIs I do
Hmmm... but mine didn't previously have the JCW kit and it still happened?
Old Sep 19th, 2004, 11:21 PM
rockymountainpenguin's Avatar
Its in my Blood!
Send a message via AIM to rockymountainpenguin
Local Time: 05:39 PM
United States View rockymountainpenguin's Pure Silver & Black 1st Gen MINI Cooper S Profile
hum...sometimes when i start my mini up...if i just tap the accelerator it stumbles...(not in a gear) then i will back out of the driveway and start to go and everthing is fine...i have had my idle drop once or twice...but my service engine soon light came on today so tomorrow we are getting all checked out..hopefully nothing too bad
Old Sep 20th, 2004, 12:53 PM
Dave&Stacy's Avatar
SCCA ClubRallyists
Bear:
The JCW kit has not been installed yet. We originally thought it would be coming with it, but the '05 kits aren't available in the US yet. So...it will be a JCW in about 4 weeks. Just haven't bothered to change the sig.
UPDATE: Molly came back from the dealer on Saturday. They replaced the intake pipe between the throttle body and the supercharger as well as the gaskets. So far, no problems. She seems to idle much better and power and gas mileage are back where they should be. We'll keep you all updated on whether we get a rough idle again.
-Dave & Stacy
Old Sep 22nd, 2004, 10:21 PM
lukebuzzy's Avatar
Motoring since 8/4/04 :)
Local Time: 11:39 PM
United States View lukebuzzy's Dark Silver & Body Color 1st Gen MINI Cooper S Profile
Mine's done it once or twice now. How occasional did your Molly do it and what was your fuel consumption?
Luke
UK Expat - Oi Oi
2005 DS/DS MCS Sport Pack, Cold Weather Pack, OBC, MFSW, Leather Seats, Anthracite Headlining & Dash
Old Sep 23rd, 2004, 02:04 AM
Dave&Stacy's Avatar
SCCA ClubRallyists
Luke:
Only did it once in about 1500 miles. Fuel economy was 29-31 before...27-29 after. Now we're back up to 29-30
-Dave & Stacy
Old Sep 23rd, 2004, 04:19 PM
speed_racer's Avatar
vroooooommmmmm
Send a message via MSN to speed_racer
United States Female View speed_racer's Electric Blue & White 1st Gen MINI Cooper S Profile
Me, too. Every morning at start up, as soon as it's turned over, it's starts to stumble, and act as if it's going to die, and then after 5 sec tops, it's ok. I know I need to get it checked out, but after only having it 22 days, I'm loathe to give it up quite yet. As it seems others may be having a problem as well, I guess I'll make an appointment for right after our local Oct. 3rd rally. *sigh*
Baxter
'05 EB/W MCS premium, sport & cold packs and HK stereo delivered 9/1/04, now featuring the auto-up circuit, the official i-pod adapter and a custom Whalen knob
Old Dec 19th, 2004, 10:22 AM
CooperS4us's Avatar
Local Time: 07:39 PM
Dave & Stacey:
Any updates regarding your rough idle fix?
Its been 3 months since your last post.
Thanks.
'02 Cooper CVT PW/B Leatherette, MFSW, 15" 8-spokes
'05 MCS CR/W Union Jack, Chrome exterior pack, Convenience Pack, H/K, Front & Rear fogs, MFSW, MINI iPod adaptor, Leatherette, Antharcite, 16" V-Spokes, ASC+T, OBC, Manual Aircon, Halogens
Old Dec 20th, 2004, 03:25 PM
Local Time: 07:39 AM
Singapore View maxxx's Classified Ads
hi there. having the same problem here too. check with the dealer and they told me that this is happening to some other cooper s too. but they have no solution for it. maybe i should just tellyour experience and hope it can help. can u update us of it since u replace the parts till now? thanks
Old Dec 21st, 2004, 01:01 PM
Dave&Stacy's Avatar
SCCA ClubRallyists
CooperS4US:
Ooops...haven't been on here in awhile. Well...haven't had any rough idle problems since they replaced the gaskets and intake pipe. From what I've read on here and on NAM, we're not the only owners who have had the pipe replaced. If you've got a rough idle issue...this might be a good place to have your tech look.
FWIW...we also had the JCW kit installed in November. We've had it a little over a month now and no problems so far.
-Dave & Stacy
Rough Idle Speed Fooj Second Generation Faults & Fixes 9 Aug 28th, 2007 08:24 PM
Rough Idle (MOD) bryce03 First Generation Faults & Fixes 6 Oct 26th, 2006 09:22 PM
Rough Idle rerenatorizlnatoizla First Generation Faults & Fixes 10 Oct 10th, 2005 01:35 PM
Rough Idle While Stopped Beaver04 First Generation Faults & Fixes 28 Dec 6th, 2004 10:05 AM
Rough Idle with CVT btsave First Generation Faults & Fixes 7 Jul 12th, 2002 07:46 PM
