Wheel Stuck on MINI- Suggestions - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 20th, 2004, 02:03 AM
HVY WGHT's Avatar
OCD MINI Owner
Local Time: 07:09 AM
United States View HVY WGHT's Indi Blue & White 1st Gen MINI Cooper Profile
I started driving down the road today and the flat tire monitor chimed and flashed. So I stopped to check the air, and the back right tire was flat, filled it up and drove home cautiously. There's a screw in it... I tried to change the tire, but after getting the lug nuts off, the wheel wouldn't budge. I tried the stuff I knew, wiggling, pulling, etc, but since the car was up on the jack I didn't want to force it too much.
Any ideas? It'll be flat when I the nearest garage is open...
The MINI has different lugs than that which I am used to.
Thanks for the advice.
IB/W MINI Cooper- Let's Motor.
Old Sep 20th, 2004, 02:32 AM
pezhead444's Avatar
United-States
Make sure the car is safely on jack stands and then hit the inside of the wheel with your foot or a large rubber mallet. I just had a flat on my Dodge Ram and it was a bear to get off because of the rust.
Old Sep 20th, 2004, 03:31 AM
bodinski's Avatar
[hot rod harlot]
Local Time: 05:09 AM
View bodinski's Indi Blue & Black 1st Gen MINI Cooper S Profile
Alternately, loosen the lugs a couple turns & let it down off the jack. A little rocking & Bob's your uncle!
Best - Bodinski
Old Sep 20th, 2004, 04:02 AM
United-States
Yep I agree with Bodinski.
Place the lugs back just with a few turns; about half way. Semi gently lower the car through the jack. This should get that stubborn wheel right off.
Be careful and make sure that the lugs are half way in.
Best Regards,
New wheel suggestions for my PL MCS I love MINI, Laura Wheels, Tyres & Brakes 35 Dec 9th, 2008 08:56 AM
Need autocross wheel suggestions minispec Wheels, Tyres & Brakes 6 Mar 31st, 2006 01:13 PM
Front wheel stuck on hub adrian.farmer First Generation Faults & Fixes 5 Jun 22nd, 2005 02:05 AM
17" wheel suggestions for black MINI minijoe Wheels, Tyres & Brakes 2 May 23rd, 2005 10:10 PM
Wheel/tire suggestions? mudshark Wheels, Tyres & Brakes 10 Apr 8th, 2003 11:36 PM
