airbag light - which connector? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 25th, 2004, 08:58 PM
Local Time: 10:27 PM
I've read multiple threads regarding this topic but haven't found a fix that can be done at home.
Has anyone successfully made this light go out without taking it to the dealer? Which connector, under the seat, is it? There's a black, blue, and yellow...anyone?
Old Sep 25th, 2004, 09:37 PM
Restyle's Avatar
Damned
Local Time: 03:27 AM
United Kingdom Male View Restyle's Hyper Blue & White 1st Gen MINI Cooper S Profile View Restyle's Classified Ads
Hi,
I`m afraid its got to be done at the dealers as the Computer needs to be reset.
There`s a common fault with the under seat loom, where the dealer generally replaces the loom for one with better connectors. While the airbag warning light is on, the airbag system will NOT Function at all even in a crash.
I had mine changed a few months ago along with Hundreds of others
See :- http://www.mini2.com/forum/first-generation-faults-fixes/2588-airbag.html
Old Sep 25th, 2004, 10:41 PM
Local Time: 06:27 PM
Mellow,
I have the same problem. I recently installed a set of Recaros, and my airbag warning light has been on since. I think it's the yellow one because the black and blue should connect to the seat belt (just trace the seat belt clip). I did some research over at NAM and found that one can actually find the resistence of the airbag that was unplug and replace it with a resistor to fool the computer into thinking everything is normal. As a result of this, operation of all other airbag will be retained. I don't think one has tried this on a mini yet...well at least I havn't found it yet.
Keep us posted if you find anything else regarding this issue, and I'll let you all know if I find anything new.
bbt4
bbt4
Old Sep 25th, 2004, 11:00 PM
Restyle's Avatar
Damned
Quote: Originally Posted by bbt4
....I did some research over at NAM and found that one can actually find the resistence of the airbag that was unplug and replace it with a resistor to fool the computer into thinking everything is normal. As a result of this, operation of all other airbag will be retained. I don't think one has tried this on a mini yet...well at least I havn't found it yet.
If only it were that Simple
The computer when first sensing any airbag system fault ..Shuts down the whole Airbag System as a safety precaution.
The system then needs to be re-initiated after subsequent investigation & repair ... a subbed resistor will NOT do this unfortunatley
Old Sep 26th, 2004, 04:27 AM
I'll take a wild guess...only the dealer can reset my airbag light.
Is this so?
bbt4
bbt4
Old Sep 26th, 2004, 03:09 PM
Restyle's Avatar
Damned
Is this so?
Yep
Hey, No need for me to type Slowly anymore
Old Sep 26th, 2004, 03:55 PM
Me and My Mini's Avatar
Cruising into the sunset
Local Time: 10:27 AM
Singapore View Me and My Mini's Pepper White & Black 1st Gen MINI Cooper Profile
airbags not working? airbag lights coming on? Thats not good news.. Especially when you know who makes them.. it only means more work..
Airbag Fitting and Airbag Light Reset Westy_1985 First Generation Faults & Fixes 5 Jul 12th, 2009 10:47 PM
Airbag Light... MarkW19 First Generation Faults & Fixes 1 May 3rd, 2006 01:23 AM
Another AIRBAG Light! The Vin Man First Generation Faults & Fixes 3 Jan 10th, 2005 06:50 PM
Airbag Light Mini4000 First Generation Faults & Fixes 2 Feb 20th, 2004 06:21 PM
Airbag Light wow First Generation MINI Cooper 1 May 13th, 2003 04:45 AM
