Power steering Pump - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 22nd, 2002, 03:04 PM
Local Time: 12:12 PM
United Kingdom View indigorallye's Classified Ads
Power teering Pump
Is anyone elses power steering pump really loud? It's the loudest pump I have ever heard and it's almost embarassing? Any ideas?
Very jealous of my mum: it's her Cooper.
Old May 22nd, 2002, 03:06 PM
monsta's Avatar
MINI2 Global Moderator
United Kingdom View monsta's Chili Red & White 1st Gen MINI Cooper Profile
Hi! Yeah, afraid they all do that...
http://www.mini2.com/forum/showthrea...&threadid=4729
the MINI has gone...
Old May 22nd, 2002, 03:11 PM
Cheers mate, that was quick. Only gripe now is the ripped seat where the stitching has come away!
Old May 22nd, 2002, 04:05 PM
Wandering....
Local Time: 11:12 AM
Male
I really like the steering noise.......
Old May 22nd, 2002, 04:28 PM
potts's Avatar
Send a message via ICQ to potts
Me too - reminds me of the fuel pump noise on Mk3 & Mk4 Ford Escorts (injection models)
Old May 22nd, 2002, 04:32 PM
monsta's Avatar
So it's true the MINI is a FORD!!!
Check out this thread if you haven't already seen it: http://www.mini2.com/forum/showthrea...&threadid=7063
Old May 27th, 2002, 03:20 AM
England
pump
The steering pump is electrically driven rather than by an ancillary belt from the engine. Means you dont lose engine power when turning the wheels.
Matter of opinion on the noise. I reckon it's quite cool!!
Old May 27th, 2002, 09:48 PM
Actually, you do lose some power when the PS pump runs, because it draws a lot of current and that loads down the alternator, which is belt-driven. The theory behind the electric pump is that it only draws power when needed, rather than running all the time as a belt-driven pump does, so it should save some fuel. Plus the fact that the engine compartment is so small, they probably didn't have room to mount a belt-driven pump anyway.
Old May 27th, 2002, 09:58 PM
chiph's Avatar
Spectator
Local Time: 07:12 AM
United States View chiph's Electric Blue & White 1st Gen MINI Cooper S Profile
42v
You'll be seeing more of these electrically-powered ancillary devices in the future. They reduce emissions by only putting a load on the engine when demand calls for it. But the automakers have determined that the 12v power that we've all grown accustomed to doesn't provide enough power to run all those new devices. The new batteries and cars will run on 42v current (36v battery, charging voltage of 42v).
BMW is a member of a consortium working on these systems. You can read more at MIT's Tech Talk newsletter.
From what I understand, the designers originally wanted a higher voltage, but the risk of electrocuting technicians and car owners was too great.
Chip H.
PS. Anyone remember the 6v electrical systems of the early VW Beetles?
ex-MINI Cooper S owner and all around good-guy
Old May 28th, 2002, 06:44 AM
England
mr bill
Mr bill. Your'e right actually. I should have put my brain in gear first. I conceed
Old May 28th, 2002, 09:21 AM
Another reason for the higher voltage is smaller wiring can be used, along with a lighter battery and smaller starter and alternator, because less current is drawn. Going to a higher voltage saves a little weight and may be cheaper to build. The downside, of course, is it forces everyone to buy new accessories, or else a voltage converter, to run their accessories.
Yes, the old VWs were six volts, but so were most cars years ago, prior to WW2 anyway. They could be converted to 12V by changing the battery, lamps, starter and generator (remember generators?), plus a radio if it had one. The 6V system used heavy wire, so converting it to 12V worked great. A friend of mine did that to an old VW he had imported. (It had the split rear window.) Military vehicles have used 24 volts for years. And do you remember when some cars used positive ground?
Old May 28th, 2002, 11:47 AM
as so many MINI'S pull left i wonder if the poor steering pump will wear out....but i quite like the noise even though it has been pointed out that it sounds like a cat stuck under the bonnet (hood for our American friends!)
Old May 28th, 2002, 05:35 PM
Blackdeath's Avatar
Send a message via AIM to Blackdeath
Wales View Blackdeath's Solid Black & Body Color 1st Gen MINI One Profile
I sometimes wish mine was, at least my old Ford Ka-3 didn't rattle
It's a MINI hearse!
KAZ 5707 - Black One with white bonnet stripes
Old May 28th, 2002, 05:38 PM
smiffy's Avatar
Send a message via MSN to smiffy
Wales View smiffy's Dark Silver & Body Color 1st Gen MINI Cooper S Profile
The sounds reminds me of an Electric Sander
S for Smiffy
"Kids in the front seat cause accidents, accidents in the backseat cause kids!"
  #15 (permalink)
Old May 28th, 2002, 05:48 PM
Blackdeath's Avatar
Thank God you've led such a sheltered life, or who knows what it would remind you of!
It's a MINI hearse!
Power steering Pump replaced-Steering slightly off centre Rooster First Generation Faults & Fixes 4 Apr 26th, 2010 01:35 PM
Power Steering Pump stargate First Generation Faults & Fixes 6 Jul 17th, 2008 06:22 PM
Power steering pump motor orvillespooner First Generation Faults & Fixes 1 Jul 31st, 2006 09:17 AM
Power steering pump GDC First Generation Faults & Fixes 0 Aug 16th, 2005 10:06 PM
Power Steering Pump virafp Maintenance & MINI Care 3 Sep 15th, 2003 12:31 PM
