cigarette lighter - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 23rd, 2002, 04:15 AM
Local Time: 06:09 PM
cigarette lighter
I don't smoke but my 12V cigarette outlet doesn't seem to work with or without the car on. Is their a switch I'm missing, the fuse bad, or is it probably defective?
BTW is the outlet always on or only when the ignition switch is on. I had a Mazda once that had to be on to charge my cell phone. Very annoying.
Old May 23rd, 2002, 04:45 AM
Morty's Avatar
* shooting pictures *
Local Time: 08:09 PM
Belgium Male View Morty's Pure Silver & Black 1st Gen MINI Cooper Profile
Hey,
I just took a look at it(never tried it before because I don't smoke)
Apparentely mine only works when I put my key in the contact.
So if yours doesn't work at all, I think you have a defective one.
Have you checked the fuse already?
Old May 23rd, 2002, 12:00 PM
thanks for the info. I'll check with my Mini dealer today
Old May 23rd, 2002, 12:09 PM
Morty's Avatar
No problem
Old May 23rd, 2002, 09:39 PM
Local Time: 01:09 PM
Smile lighter fix
In reference to your lighter problem you can try this fix.
Remove panel around lighter and most likely lighter plug is not plugged in. Have seen the same complaint before.
Old May 24th, 2002, 07:35 PM
TC
I use the boot (trunk) socket to power a tyre compressor. The handbook implies that the sockets will work with the ignition switch off.
They won't. The ignition has to be on AND the plug on my compressor has to be inserted in a specific rotational position to align with the socket contacts.
Try that.
Cigarette Lighter C11 XFF First Generation MINI Cooper S 2 Dec 20th, 2005 07:12 PM
Cigarette Lighter JS First Generation Interior & Ice 3 Oct 12th, 2005 10:05 PM
Cigarette Lighter duglia First Generation Interior & Ice 3 Aug 28th, 2005 09:21 PM
Cigarette Lighter duglia First Generation Faults & Fixes 2 Aug 26th, 2005 08:51 AM
Cigarette lighter... MiniMan7 First Generation Faults & Fixes 2 Nov 25th, 2003 03:48 PM
