Groaning noise on acceleration when cold? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 21st, 2005, 06:17 PM
oldskoolflash's Avatar
Local Time: 11:13 AM
United Kingdom View oldskoolflash's Classified Ads
Evening all!
I don't know if anyone has experienced this before? Recently I noticed a creaking/groaning noise when pulling away from standstill. It only happens at low revs when the engine is cold, and only happens from standstill (ie. not accelerating at low revs).
The only way I can describe the sound is that it is a little like accelerating when you have not disengaged the handbrake fully....
I know that if I take it to BMW, the problem will miraculously disappear as soon as I pull into the forecourt - why does that always happen
If anyone has any clues I would be most appreciative
Old Jan 21st, 2005, 08:07 PM
MINI 2 Sponsor GT Tuning
Local Time: 12:13 PM
United Kingdom View roland2003's Classified Ads
Oddly enough our demo car which is now running again after another batch of mods
has just started doing that,it also happens in reverse and only when pulling away gently.
I WILL find out what is is ,unless someone tells me/you first!
Like you say sounds a bit like a brake binding very slightly.
Regards Roland Gt Tuning
Old Jan 21st, 2005, 08:17 PM
Thanks for your reply roland. I have read the threads about the alternator belt "chirping" and simillar problems - I am no mechanic, but this seems to be too subtle to be that (if the climate contol fan is blowing or the stereo is on you won't hear it).
Doh - sorry if that last statement sounded obvious, but you know what I mean
I'd be very interested to hear your follow up.
regards,
Ben.
Old Jan 21st, 2005, 09:04 PM
No problem,
The noise Im getting is more consistent with wheel speed than engine speed,
ie driveshafts,brakes etc . Ill get it on the ramp next week and try running it up in gear
and having a listen.
Regards Roland GTT
Old Jan 22nd, 2005, 06:01 PM
Cooper76's Avatar
MotorCityMadman
Local Time: 07:13 AM
United States Male View Cooper76's Solid Black & Body Color 1st Gen MINI Cooper Profile
This happens to me and has happened many times in my BMW when very cold out. I just figured it was normal and still think it is. Although I don't know what it is exactly, I likened it to the moisture being burned off the brakes after sitting at night in the damp cold because it occurs a lot when I lightly tap the brakes after starting to move.
I don't think this is a defect...?
***BMW-AG Rocks!!!***
Portsmouth FC Can Thank Sunderland...What a Farce!!!
05 mcs 'Ratchet/scratching?' noise on accel' and de-acceleration mamba First Generation Faults & Fixes 8 Jun 22nd, 2005 01:23 AM
Flutter/Warble Noise Under Hard Acceleration Gavin1 First Generation Faults & Fixes 2 Apr 22nd, 2005 11:18 PM
Not very good acceleration when cold! Pinball General Discussion 23 Jan 28th, 2005 05:40 PM
anyone had a whistle noise on cold acceleration -? Cooper BartMack First Generation Faults & Fixes 17 Jan 26th, 2005 03:44 AM
FFFFFFFFFFFFFFFFT acceleration noise. GMINI First Generation Faults & Fixes 14 Dec 28th, 2002 08:35 AM
