H-Sport springs are on, but so are the tire pressure warning light.. - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 31st, 2005, 09:53 PM
Local Time: 11:13 AM
Norway
Hi!
I changed my original springs for H-Sport's, and I also installed a H-Sport Comp rear sway bar. This was done last Friday, and since then, the tire pressure warning light has come on twice. The pressure in the tires are OK. I "feel" the toe out are wrong, can this cause the problem? I haven't pushed the limits after the install, but if I'm 3-wheeling trough a corner, can this case the problem? Or my soft sided winter tires (215/45-17) takes so much stress in the side wall, so the system think I've got a flat tire?
I'm fixing the toe out problem during the week.
Ibsen
Old Feb 1st, 2005, 03:54 AM
Ryephile's Avatar
Deals Gap Junkie
Send a message via AIM to Ryephile Send a message via Yahoo to Ryephile
Local Time: 07:13 AM
United States View Ryephile's Indi Blue & White 1st Gen MINI Cooper S Profile
With just the rear bar - how do you know you have a rear toe issue? Are you sure you're just not used to the new [oversteer happy] suspension setup?
Not sure why your TPMS light is coming on - suspension mods make no impact on the TPMS. Did you actually check your tire pressures?
Cheers,
Ryan
Old Feb 1st, 2005, 05:16 AM
IML337's Avatar
saving the world
Local Time: 09:13 PM
Singapore Male View IML337's Dark Silver & White 1st Gen MINI Cooper S Profile
3 wheeling would cause it, but I thought the light wouldn't go off until the difference in wheel speeds had gone on for a little while.... well, longer than you're going to have your car on 3 wheels for anyway!
Old Feb 1st, 2005, 06:56 AM
TonyB's Avatar
Don MINIo
Local Time: 03:13 AM
United States View TonyB's Indi Blue & White 1st Gen MINI Cooper S Profile
That indicator works on the RPM of the wheels, as opposed to monitoring the volume or pressure of air in the tire. So, if a tire was flat, or going to that state, its circumference would differ from the rest, thus triggering the light that you might have an issue...
With that said, when one lowers their MINI, camber will change in the rear. With the tire not sitting on the ground as flat as it once did, this can make a difference in how the system perceives its RPM deltas.
I just rotated my tires where I have stock camber in the front, and probably 2 or so (neg) in the rear. After the rotation, I got that light, and I'm pretty sure the uneven wear had something to do with it...
'03 (9.6.02) MCS IB/W Lapis Blue Leather
Mission = 10:1 (Weight:HP)
Old Feb 1st, 2005, 07:39 AM
Norway
Cheers,
Ryan
My toe problem are in the front. Before the spring/bar job, I could let go of the steering wheel, and the car would go strait, but now it pull to the side. Sometimes to the right, and sometimes to the left.
Yes, I did check my tire pressures and they were OK.
Old Feb 1st, 2005, 11:53 AM
obehave's Avatar
Mini Mod
Has anything happened to the traction sensors?
An errant wrench could have done some damage.
ABS and Tire pressure warning BAZil First Generation Faults & Fixes 7 Nov 26th, 2011 12:42 AM
'02 R50 Cooper - ABS + Tire pressure warning lights on OttoMannS First Generation Faults & Fixes 3 Oct 10th, 2007 02:30 AM
Reseting Tire Pressure Warning? brassknuckle General Discussion 8 Oct 23rd, 2005 09:30 AM
Tire pressure monitor light is on..... S1monLM Wheels, Tyres & Brakes 3 Dec 10th, 2004 07:57 AM
Possibility of using 18" wheels with tire pressure warning system? M3NTAL Kev Wheels, Tyres & Brakes 3 Jul 30th, 2002 10:29 AM
