| Chers mate - its odd that the thing comes on and off though... and there is no problem on the lower settings?? Its at the dealers anyway, so hopefully they find soemthing sooner rather than later. ITs odd casue its summer here and the car is coming up to being 12 months old... PROJECT POLARIS - Die Wiedergeburt eines kultautos |
The fact... ...that it does not do "it" at the other speeds really leads me to believe that the relay, switch, or perhaps even the wiper motor are "having more than a bad day"... It may even be a combo of two or all three... you know, "electrical gremlins"... But soon you will have either confirmation of one or a combo of the above... or the dealer will hopefully find the fault even if it is not one that we have discussed. Wish you a quick and painless resolution to your problem so you can motor safely and happily once again. It is not how fast you go, but how you go. |
This thread is/was... ...a somewhat "grim" and uncanny forshadowing of an event to come !!! ..And now it has fortunately (hopefully) passed. I had exactly the same issue today. Drove straight over to our friendly local dealer and had it sorted out. The capable techs found the problem straightaway... the relay... caput. This thread actually prepared me for today's issue. It is not how fast you go, but how you go. |
| Me too This happened to me also in January. Thread "Windshield wiper failure". Anyhow the dealer replace two relays but guess what. First bad weather day since then today and its happened again on the way to work. Had to turn back and am about to drop it off for them to look at in the next little while. I'm not impressed. Its going to take a fair while to build up any trust in the wipers after this. I read elsewhere that it can be caused by an intermittent short in the motor itself. I'll post later the dealers fresh diagnosis. Very frustrating, and potentially dangerous. Last edited by MarkV; Feb 9th, 2005 at 03:25 PM. |
| guess what you guessed it about 6 months ago i was driveing to work when it justed starded to rain i managed to get to work took car to the dealer in my lunch the dealer did the usall test the fuses , wiper motor etc then i got a call a work saying that one of the multi plugs that has power to the wiper has failed (when the wipers packed in i had no wipers at all) so they would have to replace the plug but they can not just get the plug they have to replace the part of the engine harness of which no one had so after 5 days harness came then fitted job done ha ha if that was true 2 months later wipers failed i phoned the dealer they said bring it in on the way to take it in it came on i phoned the dealer said do not bother untill it failes completley so hear we are wiper goes of just when you nead it most so when this happends i lift the bonnet and start shaking the wires that i think they have touched i do not know if this is the fault but they do come on who knows it could be the motor cooling or or or not a clue help help |
| Windscreen wiper flat blades | GarethP | First Generation MINI Exterior | 31 | Dec 19th, 2008 09:23 PM |
| Windscreen Wiper Motor | KillerByte | First Generation Faults & Fixes | 6 | Oct 3rd, 2006 06:50 PM |
| Windscreen Wiper Judder | Tigger, Eeyore & Roo | First Generation Faults & Fixes | 2 | Mar 6th, 2006 06:36 PM |
| Windscreen Wiper Problem | minimattblack | First Generation Faults & Fixes | 1 | Mar 22nd, 2005 02:05 PM |
| Windscreen Wiper Problem | S33BBY | First Generation Faults & Fixes | 2 | Oct 21st, 2004 03:57 PM |
