Reverse gear difficult to engage - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 18th, 2005, 09:05 AM
Local Time: 11:28 PM
Yellow Cooper Reverse gear difficult to engage
Has anyone had problems with reverse gear and getting it engaged?
I have had the service guys look at it once and they said it was hitting the exhaust and so adjusted it.
No better and going back in on Monday!
Cheers,
Jason.
Old Feb 18th, 2005, 09:58 AM
Local Time: 05:28 PM
If you check previous posts you will find many people address this problem. It is somewhat normal of a condition, and if the driver works the shifter right the problem usually goes away. To shift into reverse, place the shifter all the way to the right, and then move it all the way to the left, in one quick motion. If you are gentle it is dificult to get over there. This solves almost all problems, and is normal for this vehicle. Remember the mechanics can fix your car, not redesign it. If it is normal, then it can't be fixed, because nothing is wrong, just percieved.
Old Feb 18th, 2005, 08:55 PM
twouptons's Avatar
What's this button do?
United States View twouptons's Pepper White & Black 1st Gen MINI Cooper Profile
Cheers,
Jason.
Our car does it. It's annoying, but not so much that we'll make a separate trip for it...
Once the car needs something else, we'll have them take a look at it.
-Eric
Old Feb 19th, 2005, 04:49 PM
Local Time: 04:28 PM
Every stick I have driven does it, there is no syncro for the reverse gear.
Old Feb 21st, 2005, 04:45 PM
kapps's Avatar
Local Time: 06:28 PM
United States View kapps's Electric Blue & White 1st Gen MINI Cooper S Profile
Actually, there is. If you look on Getrag's site, the tranny used in the MCS does indeed have a syncro on reverse. I've tested it out (moving forward slowly then shifting into reverse). I believe MINI designed reverse hard to get into just for this reason. You don't want to accidentally shift into reverse when moving at any forward speed. That would be bad . It's just something to get used to.
Reverse Gear MiniFr34k General Discussion 4 Jun 3rd, 2005 03:23 PM
Reverse Gear leightongray First Generation MINI Cooper 31 Dec 30th, 2004 10:55 PM
Reverse Gear MINI ADI First Generation MINI One D 11 Sep 5th, 2003 10:20 AM
reverse gear den123 First Generation Faults & Fixes 4 Aug 13th, 2003 12:42 PM
reverse gear bo nydal First Generation Faults & Fixes 3 Oct 16th, 2002 04:01 PM
