Odd noise when pulling away... - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 11th, 2005, 12:32 PM
Intrepid's Avatar
Gutter Princess
Send a message via MSN to Intrepid
Local Time: 10:33 AM
United Kingdom View Intrepid's Chili Red & White 1st Gen MINI Cooper S Profile
Question Odd noise when pulling away...
Hello..
My Mini makes a weird sound when I pull away from a standstill... or reverse from a standstill.. It sounds like it's my exhaust resonating, but it's not because I've had it checked. It's like a vibrating, rattling (if I could imitate it, it would sounds like a 'ddrrrrrrrrrrrrrr' noise!). It doesn't happen every time either. What could it be? Drive shaft/steering? Wheel barings?? I hope it's not serious. Doesn't affect the driving or performance at all...
Any ideas?
Thanks everyone.
Old Mar 11th, 2005, 12:34 PM
ButtonIt's Avatar
www.totalmini*****
Send a message via MSN to ButtonIt
England Male View ButtonIt's Hyper Blue & Body Color 1st Gen MINI Cooper S Profile View ButtonIt's Classified Ads
There's been some posts on here about clutch problems.... I'll have a bit of a dig
Old Mar 11th, 2005, 12:37 PM
ButtonIt's Avatar
www.totalmini*****
http://www.mini2.com/forum/showthrea...noise+problems
Old Mar 11th, 2005, 12:43 PM
scooperman_uk's Avatar
almost 59k
Local Time: 11:33 AM
United Kingdom View scooperman_uk's Solid Black & Body Color 1st Gen MINI Cooper S Profile
heat shield above the exhaust manifold might be loose or vibrating. if so u just need to bend it away from the obvious areas. u can reach this thru the engine bay, its behind the steering pump assembly.
Old Mar 11th, 2005, 01:01 PM
Hickster's Avatar
Totalled
Send a message via MSN to Hickster Send a message via Yahoo to Hickster
United Kingdom Male View Hickster's Pepper White & Black 2nd Gen MINI Cooper Diesel Profile View Hickster's Classified Ads
Shell's Mini has the same problem, although it sounds like it coming more from the back of the car than near the engine bay. She's taking it in next week to have it looked at.
D-lite-full
Old Mar 11th, 2005, 01:12 PM
Intrepid's Avatar
Gutter Princess
thanks guys - you're all brilliant. Looks like it might be clutch then as I've had heat shields checked etc
Better book her in...
Wandering....
Male
Thats the noise I had - my dealer fixed it eventually - could be the heat shield alright- is it only happening when the engine is under load? May be caused by the engine moving on its mountings.........
Old Mar 11th, 2005, 01:22 PM
ButtonIt's Avatar
www.totalmini*****
My heat shield came away completely last week and got wedged against the steering column, meaning I couldn't turn left properley
Noise when pulling away (mini cooper s) Jaw_F430 First Generation Faults & Fixes 2 Oct 2nd, 2007 09:13 PM
Rubbing Noise when pulling of in 1st in the Morning Rashid First Generation MINI Cooper S 17 Sep 3rd, 2007 11:48 PM
Hose/Odd Noise Question pregan First Generation Faults & Fixes 5 Apr 22nd, 2006 01:42 PM
Loud noise when pulling away?? timlowden771 First Generation Faults & Fixes 8 Mar 21st, 2002 04:14 PM
Clank noise when Pulling away. minimus First Generation Faults & Fixes 20 Jan 30th, 2002 04:22 PM
