Hyperactive turn signal / turn indicator behavior - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 13th, 2005, 07:23 PM
CooperCooper's Avatar
Local Time: 12:42 PM
United States View CooperCooper's Electric Blue & White 1st Gen MINI Cooper S Profile
I've been having trouble with my right side turn indicator lately. It suddenly started flashing much more rapidly that it normally does. The left indicator continues to behave normally. In older vehicles, I would take this as a sign to replace a faulty flasher, but I take it that the Mini no longer has such an item.
Searching the forums, I've seen two possibilities. One is that the on-board computer is causing the problem and needs a reset (battery disconnect for ~10 mins?). The other possibility is that there is some sort of short in the indicator lamp housing.
Any ideas on which of these two might cause the signal on only one side to behave poorly? Should I just go ahead and reset the on-board computer and see if this fixes the problem and, if not, assume it's a short? Are there any downsides to resetting the on-board computer?
Thanks for any advice!
CooperCooper
2003 MCS EB/W - Premium, DSC, Fogs
1966 Austin Healey 3000 mkII - garage art
Old Mar 13th, 2005, 07:36 PM
mikeythemini's Avatar
Local Time: 08:42 PM
I would normally expect 1 of the bulbs to be out
Old Mar 14th, 2005, 09:46 PM
Local Time: 02:42 PM
Canada Male
Change the bulbs before doing anything else..
Old Mar 14th, 2005, 11:15 PM
SteveM3's Avatar
Local Time: 07:42 PM
Sounds like a bulb failure. Reminds me of marketing b/s when a car brochure claimed
the car in question had this clever engineering that if a bulb failed the indicator would
blink faster to warn you. As far as I am aware this happens on every car .
Turn Signal Programming e46jb Second Generation Interior & Ice 11 Aug 26th, 2007 11:56 PM
Turn signal broken tompr1 First Generation Faults & Fixes 1 May 30th, 2006 05:00 AM
Weird Turn signal behavior NYCguy First Generation Faults & Fixes 2 Feb 11th, 2004 02:32 PM
White rear turn signal peppericee First Generation MINI Exterior 7 Dec 8th, 2003 11:44 PM
Side Turn Signal Defect prs First Generation MINI Cooper 2 Nov 4th, 2003 05:21 AM
