Any one buying Miltek exhaust from amd beware ( ANOTHER MILTEK LOOSING BOLTS ISSUE) - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 21st, 2005, 05:12 PM
Black&WhiteScooper's Avatar
Local Time: 11:34 AM
England View Black&WhiteScooper's Solid Black & White 1st Gen MINI Cooper S Profile
Hello- Got a bit of a problem with the mini at the moment... think its the miltek exhaust causing it but im not sure.
Basically for about the last month the exhaust system has sounded much louder and raspy when cold--- It didnt sound unpleasant and this has quickly gone away when the system warmed up after about 5 minuits of driving.
Last week I noticed a ticking sound coming from the rear of the car on idle-- this went away as soon as i accelerated. I had put this extra noise down to the exhaust bedding in a bit and changing tone as this has happened with all other exhausts i have had.
However the last couple of days the exhaust has been sounding louder and luoder when cold and instead of the normal lift off ' popping sound' i have been getting more of a cracking noise on lift off.
Today the car sounds like a tractor and has not improved after a 15 minute drive... The whole car is shaking from the exhaust vibration--- really loud raspy noise--- passers by are staring at me coming from miles away.
I am taking the car back to the people who supplied and fitted the exhaust so they can look at it. I fit is not the back box then its going back to bmw.
Anybody hazard a guess as to what has happened... its a miltek back box, but every thing else on the system is standard
Old Mar 21st, 2005, 05:25 PM
ButtonIt's Avatar
www.totalmini*****
Send a message via MSN to ButtonIt
Local Time: 10:34 AM
England Male View ButtonIt's Hyper Blue & Body Color 1st Gen MINI Cooper S Profile View ButtonIt's Classified Ads
Check the bolts between the cat section and the miltek. Mine came loose last week and one of them fell out completely, resulting in a bit of blow at the flange.
The flange is located just behind the front wheels, in the centre of the car. There should be two bolts, nice and tight.
Old Mar 21st, 2005, 05:29 PM
Thanks--- I will have a look in the morning
Old Mar 21st, 2005, 05:50 PM
ok--- ive just jacked the car up and its fairly obvious what the problem is---- the cat pipe is no longer connected to the exhaust system:!:!:!:!:!
I cant see whether it has sheared off or whether the bolts have just come off- looks like the bolts have fell off, nut the system is defininately disconnected just behind the front wheels------ another great piece of work by AMD...I was warned not to use them but i thought i could trust them to fit a back box--- fuking idiots
Old Mar 21st, 2005, 05:52 PM
ButtonIt's Avatar
www.totalmini*****
AMD fitted mine too, and they still haven't sent my exhaust yet It'll just be the bolts fallen out. I fitted another spare bolt that I had to secure it till I take it back. It's not the "correct" size, but it fits and holds, especially with two locking washers.
Get on the phone tomorrow mate
Old Mar 21st, 2005, 05:53 PM
I CURRENTLY HAVE NO BOLTS IN PLACE . Out of interest who fitted your exhaust buttonit.
Old Mar 21st, 2005, 06:01 PM
Rakey's Avatar
Total MINI dot com!!
United Kingdom Male View Rakey's Classified Ads
AMD fitted ButtonIts exhaust
they loosen as they expand and contract under heat and cooling. You need to get some locking nuts, and perhaps use a drop of thread lock too
Old Mar 21st, 2005, 06:04 PM
I will have to mate---- but this should have been done by AMD-- It obviously wasnt done properly
Old Mar 21st, 2005, 06:07 PM
Rakey's Avatar
let us know what AMD say, as they really should have got this right when fitting
Old Mar 21st, 2005, 06:11 PM
Will do---- They will be hearing from me tomorrow
Old Mar 21st, 2005, 07:34 PM
AA have just been out and secured the system--- The wrong bolts have been used to secure the entire system---- Its a miracle its stayed on for the three months that its been fitted..... AMD are gonna get a mouth full tomorrow
Old Mar 21st, 2005, 07:35 PM
Berthil's Avatar
Netherlands Male View Berthil's Electric Blue & White 1st Gen MINI Cooper S Profile
I fitted a Milltek catback a month or so ago too, but I have had no problems.
http://www.mini2.com/forum/first-generation-mini-tuning/83783-milltek-exhaust-fitted-today-my-mini-cooper-s.html
A friend who has a garage-company had done it for me. I think I will pay him a visit before I loose some metal pieces . There were bolts in the whole Milltek package, so we used these.
EB/W R53 MCS Highly Modified
Old Mar 21st, 2005, 08:36 PM
The problem seems to be that the rods that the bolts go onto are quite short--- AMD havnt used those weird nuts that lock themselves--- just used standard nuts and bolts--- only a matter of time before these rattled loose
Old Mar 21st, 2005, 08:39 PM
The offending joint is the one right at the bottom of this picture
  #15 (permalink)
Old Mar 21st, 2005, 08:53 PM
Have you checked your gasket is still there--- mine had been snapped and blown out
Cooper S Miltek Exhaust Wardpaa Second Generation MINI Cooper S 2 May 3rd, 2007 07:21 PM
Miltek exhaust...... kipper First Generation MINI Cooper S 23 Jun 14th, 2006 09:14 PM
cooper s miltek exhaust on a one? webb23 First Generation MINI One 1 Apr 13th, 2005 10:07 PM
FAO anyone who has the Miltek exhaust fitted by AMD..VERY IMPORTANT YOU READ THIS!!! Black&WhiteScooper First Generation MINI Tuning 1 Mar 21st, 2005 11:43 PM
