| Hah! The real question is 'should my brake light be on after MTM2005?', ![]() Owen. |
| Worth checking the rears too.... I replaced my fronts at 18k, only to find out that its the rears that need replacing. Don't assume that your rears will last significantly longer than your fronts, they are now designed to wear down evenly (the rear pads are thinner than the fronts). 11k seems vey low, perhaps your driving style needs some consideration...? |
| the black paint is still there, i must try and get rid of it I swapped my front and rear tyres yesterday again, and i did notice the fornt brake pads where very thin, the rears seem'd okay. Then i went out for a small run and i was pretty heavy on the brakes which must have done the damage .I'd like to get a decent set of pads and braided hoses but dont really have the cash now??? I might just book it in to my dealers |
the service interval will tell you when you need to change your brake fluid when you turn the key to position 2 the service interval will tell you miles or km to a service press the button in the speedo and a little clock symbol will appear beside this is the amount of days left till you need a brake fluid change if it is a minus number get it sorted asap drop down some time and ill change your pads and fluid |
no you can reset the brake fluid clock they same way you reset the service interval also only buy the pads from a BMW dealer as you will need a BP sensor cable also and some antisqueal paste the sensor cable must be replaced as once the switch on the cable is activated it cannot be reset once you change the pads and replace the cable the light should go out one other thing have you checked the brake fluid level maybe your pads are ok and just need a fluid top up or change check this first before buying any pads also check the pads for thickness you should be able to see them through the wheel spaces and let me know always here to help a MINI in distress |
| Thanks i have looked at the thickness of the pads and they dont look too thick I wanted to get new pads anyway for tracking.I ordered some new rear pads from BMW but got ferodo ds2500 for the front and getting some braided hoses and some dot 5.1 brake fluid. Also i got a BP sensor for the front and the rear from BMW. It should do the job |
| where ya tracking, did ya do any other mods since we met over the promini intake i still have and use the intake also fitted 15% reduction pulley going to get GIAC next also looking into the possibility of a cryo system (DIY job) |
| Brake pad sensor | dazzpowder | Maintenance & MINI Care | 2 | Feb 7th, 2007 02:54 PM |
| Brake pad sensor Q on 02 MCS | texascadillac42 | Wheels, Tyres & Brakes | 1 | Sep 11th, 2006 06:49 AM |
| disabling the brake pad wear sensor light on the dash? | scooperman_uk | Maintenance & MINI Care | 2 | Aug 14th, 2006 01:15 PM |
| Brake pad sensor at 20K | xnetco | Wheels, Tyres & Brakes | 11 | Feb 2nd, 2006 08:09 AM |
| Another Brake pad sensor light Question | Fabio | First Generation Faults & Fixes | 15 | May 18th, 2005 02:51 PM |
