"check engine" icon light.... (SES) fuse location - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 18th, 2005, 09:35 AM
eddieboyII's Avatar
"knucklehead"
Send a message via Yahoo to eddieboyII
Local Time: 06:35 PM
Philippines Male View eddieboyII's Chili Red & White 1st Gen MINI Cooper S Profile
ey guys, i just want to know if when you turn on the ignition but not start it, will this icon above the EML light should turn on? all the indicator lights seemed to turn on like the eml, airbag, brakes, runflat indicator, etc etc... and after a while it will go off... it's just that engine icon won't light... is that normal??? i've already tried to remove the fuse, the EML light won't turn on... (do they share the same fuse?) and the fuse is fine...
need help.... i'm a bit worried....
-->ed
Old May 18th, 2005, 11:06 AM
eddieboyII's Avatar
"knucklehead"
help help!!
Old May 18th, 2005, 12:31 PM
Bert.'s Avatar
MCS EB/W
Local Time: 11:35 AM
Greece View Bert.'s Electric Blue & White 1st Gen MINI Cooper S Profile
-->ed
Engine light should turn on (mine does) It's something like check before turn the ignition on.
If I was in your shoes I will be going to check this out at my service.
Hope that help you
Old May 18th, 2005, 12:41 PM
eddieboyII's Avatar
"knucklehead"
Hope that help you
oh i see.. the problem is we don't have any mini dealer here in our country.... i have a diagnostic tool but it read "no faults"... what seems to be the problem? the other indicator lights including the EML turned on but not the engine icon.... might be the fuse or something... but i'm not sure where the fuse for this indicator is located... i removed one and the EML did not light so i put it back in... anyone knows where the fuse for this engine indicator located?
-->ed
Old May 20th, 2005, 04:54 AM
eddieboyII's Avatar
"knucklehead"
anyone knows where i can find the fuse for the check engine light (SES)? that might be the cause... i think...
Old Jun 18th, 2005, 12:14 AM
Local Time: 10:35 AM
same problem
I've experienced the same problem as you but mine is 523iSE not mini. I've sent my car to a BMW dealer last week and they said it was an air leak in one of the cable and they fixed it, and charged me £98 . But, when I picked my car up I noticed that nothing has happened (EML is OK but engine indicator didn't lit up). I called them again and fixed another appointment next week. By the way, did you find the solution eddie?
"Service Engine Soon" light at 1200 miles?! Kraigster414 Maintenance & MINI Care 7 May 20th, 2005 08:30 PM
LED Marker lights and "Check Engine Soon " Light ! Kenmini First Generation MINI Exterior 2 Apr 6th, 2005 01:07 AM
What Else? "Check Engine Soon"! VincentHill First Generation MINI Cooper S 8 Jul 31st, 2003 12:30 AM
"service engine soon" light fishie <///>< General Discussion 4 Feb 20th, 2003 07:47 AM
