clunking noise when turning the wheel Hi can anyone help me im having a problem when im turning the steering wheel i hear a clunking noise. i pulled down the plastic cover that is located under the steering wheel and i noticed that the noise is coming from the two rods that are jointed together (sorry not very good with car part names) and i also hear another clunk that is coming from further inside where there is another plastic peice covering it... has anyone else had this same problem? can i just simply lube up the part where the two parts are jointed together so they can twist smoother when turning the steering wheel? can anyone help? thanks |
| i dont know if its the same over in Oz.. but you could always ask your dealer to put in a Goodwill claim to MINI HQ and see if you get a result. Always worth a shot if you ask me Hope you get it sorted! |
| sorry to drag this thread up I got a New Mini, its under warranty so i am not that concerned, I just wanted to get a bit of info before i take it in, just in case they try and fob me off car:53 plate JCW mini cooper s Its had a new upper steering column and PAS pump fitted under warranty via previous owner symptoms: when turning the wheel left (whilst the car is at a standstill) its clunks, only have to turn it 90 degrees or so it don't do it when turning the wheel right |
| HELP!! Squeeking noise possibly from left from wheel when turning at start off | sam_pd | First Generation Faults & Fixes | 7 | May 24th, 2007 01:13 AM |
| clunking noise from rear | steve1968 | First Generation Faults & Fixes | 3 | Jan 12th, 2005 07:23 PM |
| Clunking noise from underneath! | SMARTIE | First Generation Faults & Fixes | 3 | Dec 13th, 2004 12:38 PM |
| knocking/clunking noise?????????? | ASTON | First Generation Faults & Fixes | 5 | Apr 30th, 2004 10:29 AM |
| Clunking Noise | Bonnie Scotland | First Generation Faults & Fixes | 6 | Nov 17th, 2002 04:05 AM |
