| loose front wheel - help ! Hey all, First post - hope you might be able to help but please bear with my long rant ! My problems started some months back when I had two new front tyres fitted to my beloved Cooper S (Pirelli run flats) Almost straight away I noticed that I was loosing air (roughly 4-5 psi) in the front left tyre. It's some months down the line now and after countless visits to the Tyre shop things seem to be ok...they insisted that it was not the tyre but that air was escaping through the rim of the tyre possibly due to my refurbished alloy. My last visit was a few weeks back where once again they removed the wheel for what was probably the 5th time and checked things over. They sprayed fairy liquid over the tyre and it was clear to see bubbles appearing in certain areas of the wheel rim - they followed this up by removing the tyre and pasting the rim with a white gunk before fitting the problem tyre back again. Since then I haven't been losing air which leads me to believe that maybe they were right. It's been 2 weeks and I've been checking my air - no problems however tonight I take the car for a wash and notice one of my four wheel nuts missing and one loosely hanging out by it's thread ! Each time they have removed the wheel I have watched them replace it using an electric device to tighten the nuts back in - I don't understand how this has happened - I'm pretty mad tbh as I was due to take a long trip on the motorway tomorrow..who knows what might have happened had I not noticed this. Is it possible that having the wheel taken on and off so many times has now caused the threads to loosen causing this the nuts to loosen and drop out ? Should the tyre company take responsibility here for this problem and possibly a replacement tyre too ? Any thoughts much appreciated ! TimmyR |
| If the tyre shoppe used an electric or pneumatic tool to remove and tighten the bolts it is entirely possible that they have stripped the threads of either the bolts or the hub. DJC is on the right path. Remove the wheel, then test insert the bolts one at a time into each hole and compare how they feel. Is it possible to wiggle any of them once screwed into the hub? Take off any of the other wheels that has not been off recently and compare the feel of the fit of the bolts in the hub. Are they the same? If the front wheel that lost a bolt feels looser, the culprit is the tyre dealer/installer. Final torque should always be with a torque wrench, according to the factory. Almost never done outside of the factory. Motor on, Dudes and Dudettes!!! '06 MCS SB/S '02 MCS DS/W (retired) |
| 05 Aero kit front bumper removal (loose) | JMWhittaker | First Generation MINI Exterior | 4 | May 5th, 2007 05:11 PM |
| Loose Steering wheel | MiniFr34k | First Generation Faults & Fixes | 10 | May 26th, 2006 04:29 AM |
| HELP - Loose wheel arch | CARVNIT | First Generation Faults & Fixes | 0 | May 19th, 2005 12:05 AM |
| Loose steering wheel | Miniphobea Teen | First Generation Faults & Fixes | 10 | Jun 11th, 2004 03:48 PM |
| Front wind screen moulding coming loose | toofast | First Generation Faults & Fixes | 2 | Mar 1st, 2003 10:46 AM |
