Filling up with gas... PROBLEMS - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jul 18th, 2005, 09:04 PM
Waiting.....
Local Time: 06:37 AM
Canada View eclaire's Chili Red & White 1st Gen MINI Cooper S Profile
Canada Filling up with gas... PROBLEMS
I have been having this problem with my Mini since I first got it. It is a 2004 MC and on and off, when I try to fill it up with gas the pump will click off like my tank is full even though Ii KNOW it is not. If I try ro keep filling it, the gas will overflow.
I've taken it in and of course the dealership said there was no problems. I have tired different gas stations and nothing works. It will just decide that after a few hours it will take the gas.
Anyone else experience this????
Old Jul 18th, 2005, 09:12 PM
cooper_s_flyer's Avatar
Carpe Diem
Local Time: 05:37 AM
United States Male View cooper_s_flyer's Solid Black & Body Color 1st Gen MINI Cooper S Profile
United-States Yes...
... I utilize the "slow speed' of filling after the initial click and all is well. Also, pulling up on the spout until it is almost visible in the filler neck works wonders. Full tanks plus approximately 1.3 gallons (filler neck and very top of tank) are possible this way.
Wierdly, I found that Chevron, Shell, and Texaco have the least problematic pumps.
It is not how fast you go, but how you go.
Old Jul 18th, 2005, 09:26 PM
Waiting.....
Canada Thnks
At least I'm not the only one... However I have found myself stranded for 6 hours about 115km away from home. Not fun.
Old Jul 18th, 2005, 09:43 PM
BigGerald's Avatar
Local Time: 04:37 AM
if it makes you feel better...
I used to have to do this with my jeep wrangler... the thing would take MAYBE 3 gallons of gas before it shut off... the tips coopersflyer gave work well (especially the light squeeze "technique"), but be careful not to overfill the tank...
Sorry bout your problems.. good luck!
Old Jul 19th, 2005, 12:00 PM
RenaultF1's Avatar
Of course it is...
United States Female View RenaultF1's Liquid Yellow & White 1st Gen MINI Cooper S Profile
You are definitely not the only one. I ended up switching gas stations for my regular fill-ups and since then when I'm around home I don't have the problem. When I travel I try to use either Mobil, Shell or Irving...I'm yet to find an Exxon station that works properly.
Oh and the tips above, definitely work if you run into an uncooperative pump.
Old Apr 9th, 2006, 01:08 AM
Local Time: 10:37 AM
I have had problems with this too. I have a 2003 MC S and It looks like my MC is the one that decides when she's hungry. I have sometimes spent an hour going from gas station to gas staion with no luck. Not to mention spending like .08 cents at each gas pump, then my credit card company thinks I stole my card!!!
Some people tell me it's the build up of pressure and you need to release it some how. What I usually do is everytime this happens, I have to either wait 2-3 hours till the MC decides to fuel up...or sometimes it does it on the second try at a different gas station.....it's a crapshoot really. Now I try to fill the tank at half. Sucks if you're on a road trip. I can't believe Mini won't acknowledge this.
I mean, is there a recall on this?Breather valve maybe?
~Rory
Old Apr 19th, 2006, 10:03 PM
William Courant's Avatar
Local Time: 03:37 AM
Think this must be a characteristic of the design of the fuel tank/filler tube with the number of people commenting on this. All cars do this to a certain degree but the Mini seems paticularly sensitive to this. The fuel nozzle cut off is indeed activated by pressure. As the pollution guys don't want people topping right up (they say it causes pollution) most of the nozzles are set to go off before the tank is actually full to capacity. What works for me on my 03 Mini Cooper is pump away until the nozzle clicks off, count off 10 seconds and pump again, count off another 10 seconds and pump again. At this point the tank is full to the brim. Don't know why this works, I suppose something to do with giving the pressure built up during the intial fueling time to subside a bit.
Hope this helps
A car, A legend, A way of life
Old Apr 20th, 2006, 06:20 AM
DaFlake's Avatar
MMC Member
Don't push nozzle all the way in. This is what works for me.
Old Apr 20th, 2006, 02:09 PM
PPE's Avatar
PPE
Painting the town purple
Local Time: 09:37 PM
Australia Male
Some pumps are a little tricky, this is just the nature of their makes. You'll find that if you change petrol stations enough you will find that some are very easy to use while others can be a real pain.
I've found this with driving all over the country, even in our other car (a Toyota) I've had these problems. It has nothing to do with the car and more to do with the model of gas pump.
Rich
Old Apr 22nd, 2006, 08:33 AM
Madeira Jon's Avatar
Madeira Male
I always place the pump on its side. All my cars have the problem regardless of make.
Filling up ben__allen MINI Cooper Diesel 12 Mar 17th, 2008 05:33 PM
The New E-10 gas .. problems.. MetalMiniMayhem First Generation Faults & Fixes 208 Nov 2nd, 2006 10:31 PM
Gas MIleage Problems in my S Charlie Brown First Generation MINI Cooper S 13 Aug 15th, 2004 07:08 PM
faulty gas valve problems -- undetected? KTC First Generation Faults & Fixes 1 Apr 13th, 2003 04:42 AM
