| OEM driving light are not totally water tight and are prone to condensation, this is quite common but keep an eye on any internal corrosion that may occur. I know Mini have change supplier for these driving lamps as the old OEM lamps are very prone to corrosion. |
| Definitely bring it to your dealeers attention right away and get it entered into your service record so that if it becomes a problem in the future you already have it on record as a warranty issue. An ounce of prevention is worth a pound of cure. Motor on, Dudes and Dudettes!!! '06 MCS SB/S '02 MCS DS/W (retired) |
| The same happened to my driving lights when the car was washed at the dealer - the only place where its washed by a machine. However whenever it rains or I wash it with a "water pistol" no condensation appears so I just gave up washing my car at the dealer |
| Condensation on Inside of Windscreen | rec | Second Generation Faults & Fixes | 26 | Jan 27th, 2007 05:06 PM |
| Condensation inside sunroof | fergusor | First Generation Faults & Fixes | 2 | Dec 21st, 2006 08:43 AM |
| Halo driving lamps to match side lights- see inside | obehave | First Generation MINI Exterior | 14 | Mar 25th, 2006 03:57 AM |
| Condensation on inside of Headlights Fault- Yes or No | Gavin1 | First Generation Faults & Fixes | 12 | Oct 4th, 2004 07:26 PM |
| MY own driving lights Kit -pics inside- | Kissato | First Generation MINI Exterior | 6 | Jul 31st, 2004 04:00 PM |
