Reversing Light. - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Aug 7th, 2005, 05:32 PM
Local Time: 11:37 AM
United Kingdom View DAVEYROBBO's Pure Silver & Black 1st Gen MINI Cooper Profile
England Reversing Light.
Hello Mini people,
Has anybody had a problem with their reversing light failing to work?
I have changed the bulb and the fuse but still no joy, read in a previous post about a control box which tells the car its in reverse anyone know where that is or is it likely to be a wire come off from the gearbox? Any suggestions?
Regards
Davey
Old Aug 7th, 2005, 06:59 PM
Local Time: 06:37 AM
5 spd or 6 spd
Old Aug 7th, 2005, 07:11 PM
Profpatpending's Avatar
Forum Hardened
Local Time: 10:37 AM
well on your cooper the back up light switch is located on top of the tranny under the air filter box try that first
Old Aug 7th, 2005, 08:41 PM
England 5 Speed
Mini Service, It is a 5 speed box on a 2002 Cooper
Regards
Old Aug 7th, 2005, 11:17 PM
like profpatpending said it is on top of the gear box under the air filter housing, there is two wires goin to it, put the car in reverse and check for battery voltage on both wires, if you have battery voltage on one and not the other you know the switch is bad
Old Aug 8th, 2005, 02:01 PM
CoryB's Avatar
United States Male
Just replace the backup light switch.
I had my MINI in 3 different times because the reverse light stopped working. First time they installed a bulb and it worked for less than one day. Second time they installed a new light assembly - worked until I got home. Third time they finally replaced the switch and it's been working ever since.
The odd thing is that there was enough current to light up a test light and read properly on a volt/ohm meter, but wasn't enough amperage for the actual bulb to light. Once they replaced the switch, it worked.
His - 04 CR/W MCS
Hers - 05 BEP/W MCS
Old Aug 8th, 2005, 06:28 PM
Pure Silver Thanks All!
Now I've just got to find the time to do it!!!
Old Aug 9th, 2005, 01:01 PM
Local Time: 05:37 AM
Bad Reverse light switch
My MCS was built 9/ 2003
Reverse light switch went bad this spring at about 12,000 miles.
Dealer changed it.
On the S, you can get to it through the left wheel well with out jacking up the car.
John
Reversing light bulb ianmull General Discussion 6 Jan 17th, 2008 12:03 PM
Chrome rear fog bulb - reversing light retro fit MINI_Chris First Generation MINI Exterior 2 Apr 23rd, 2006 03:40 PM
Reversing Light pmitch General Discussion 2 Dec 28th, 2005 11:47 AM
Reversing light. How do I change the bulb? herbie27 First Generation Faults & Fixes 11 Dec 16th, 2005 01:48 PM
Reversing light not working johns First Generation Faults & Fixes 1 Nov 27th, 2004 08:05 PM
