CD Player Makes Noise When Door Is Opened - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Aug 14th, 2005, 04:09 PM
Local Time: 05:37 AM
United-States CD Player Makes Noise When Door Is Opened
Hi all:
I have a 2005 Mini Cooper S with the single slot CD player. I have had the car for only a week but I have noticed something interesting about the cd player when ever I open the door after it has been sitting unused for a few minutes.
For example, if the car has been sitting in my garage and I then get in, the CD player motor activates like it is trying to eject or accept a CD. It does not do this if there is already a CD in the player. It will also make this noise if I sit in the car and then lock or unlock the door after waiting a minute or two. Has anyone else experienced this quirk?
Old Aug 14th, 2005, 07:01 PM
Exlotusboy's Avatar
Local Time: 06:37 AM
United States View Exlotusboy's Solid Black & White 1st Gen MINI Cooper S Profile
I have the same "problem" - I'm using quotes for now, as this may just be a design quirk. Found your post while searching this topic. If I find out anything, I'll let you know.
You're not alone!
Old Aug 14th, 2005, 07:09 PM
Exlotusboy's Avatar
After doing a search, no info on this issue. Anybody have any ideas?
Old Aug 14th, 2005, 09:47 PM
Exlotusboy's Avatar
According to a member of the "North American Motoring" group, this issue is not normal.
Just passing along this bit of info.
Old Aug 14th, 2005, 10:23 PM
Did the member on North American Motoring give any more details on the problem. Do you have a link for it?
Old Aug 15th, 2005, 11:25 AM
Local Time: 11:37 AM
United Kingdom View rickyh's Solid Black & Body Color 1st Gen MINI Cooper S Profile
Could be the fuel pump priming... kind of a buzz/zizz a bit like the cd eject motor.
But then... so what? All part of the fun. Cooper S makes far more interesting noises than this
Old Aug 15th, 2005, 08:37 PM
Exlotusboy's Avatar
Several other U.S. MINI drivers have noted this noise on their '05 MCS's. Given the number of people who are saying they have the noise, I'm starting to wonder if it's just a quirk. The noise in question is definitely the CD player - not the fuel pump.
Still gathering info...
Old Sep 5th, 2005, 10:09 PM
Local Time: 02:37 AM
I actually own a 2004 Standard Cooper. I just had the CD player replaced this year, due to it skipping on everything. Now it makes the noise (as described here) whenever I open the door. Looks like I'll be heading back to the service department again...
Window retraction or my window won't go down when the door is opened minimini36 First Generation Faults & Fixes 15 Nov 27th, 2010 08:07 PM
Window makes bang noise pubert Second Generation Faults & Fixes 0 Feb 17th, 2007 10:42 AM
passenger door cannot be opened Gr1zzLy First Generation Faults & Fixes 3 Jul 6th, 2005 02:07 AM
Door opened by itself on motorway! roomey First Generation Faults & Fixes 1 Jan 5th, 2004 01:28 PM
