| Glad to be of service ![]() For the side vents just pop off the dash end covers & drill a small hole in the duct, a couple of inch beck from the vent & towards the top - then play around with angles once you have them wired up The middle vents are a bit harder - remove the centre dash section & speedo then do the same Wire them to the sidelight feed on the stereo or cig lighter. The biggest problem with these is getting a decent pic as digy cameras dont pic them up well Still one aof my favourite mods - subtle but cool - other minis seem so dark inside |
| I found the centre one's the easiest to do, then came the driver side one, that was OK as well, but how the heck do you get to the passenger side one. I can get the vent off ok, but the gap is so small to get the LED through and with the air bag next to it as well Has anyone managed to to this as well, if so how did you get the LED in place? Also where did you earth it to? Thanks. Will try to take some Pic's Later when its dark. Last edited by Phoenix; Oct 29th, 2005 at 04:10 PM. |
| To do the central vents - just pull the centre section of the dash out as per your chromeline DIY ![]() To do the side vents just unclip the dash end trims when the doors open. You can get a drill in & do a small hole near the top of the vent pipe. Then wire all the leds - one side to chassis the other side to the sidelight wire on the stereo (orange on my hanress adaptor) Grey/ ??? on the factory harness |
| After market accent lighting LEDs | JMWhittaker | First Generation Interior & Ice | 1 | Nov 19th, 2005 07:49 PM |
| Additional interior/accent lighting | minicore | First Generation Interior & Ice | 13 | Oct 7th, 2005 08:50 PM |
| Navigation Voice Accent | Sneeper | General Discussion | 18 | Apr 29th, 2003 03:37 AM |
