Door panel removal help please. - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jul 3rd, 2002, 01:18 PM
Local Time: 03:40 AM
Unhappy Door panel removal help please.
I've found a couple postings about removing the door panels but they haven't helped me.
There is a good writeup in Dom's thread by space_cadet but I need more.
I was thinking of using 2 metal spatulas and a wooden wedge to get the !#@$ things to pop off, has anyone tried this?
Does anyone have a secret?
Does anyone have a closup picture of the fasteners?
TIA
-John
Old Jul 3rd, 2002, 01:52 PM
Dom's Avatar
Dom
Test thread infiltrator
Send a message via MSN to Dom
Local Time: 11:40 AM
England View Dom's British Racing Green & White 1st Gen MINI Cooper Profile
You'll need something that won't bend, and make sure it's protected by tape or something so that it won't damage the paintwork.
I started on the middle of the right hand side - work your way DOWN... the top is held on by different clips. Just bend the door card towards you slightly and pull...
Dom
Old Jul 3rd, 2002, 02:04 PM
JonBlakeburn's Avatar
Indecisive MINI Owner
Send a message via ICQ to JonBlakeburn Send a message via MSN to JonBlakeburn
View JonBlakeburn's Indi Blue & Body Color 1st Gen MINI One Profile
Dom
Would that be a left pull or....
Jon Blakeburn
2002 Raven Blue Lupo GTi
Old Jul 3rd, 2002, 02:05 PM
Thanks everyone!
space_cadet was nice enough to send me this, maybe it will help someone else as well.
I thought there were only the 3 torx screws, glad I didn't force anything.
"It does take some pulling - also there are 4 torx screw - there's one hidden behind the red reflector.
Try this. Wind the window all the way down. Put your fingers
behind the top of the door panel right at the front of the door where it curves up slightly. There is a bit of a ledge here so you can get some good leverage. A VERY sharp tug should get you started and open up a gap so yuo can work your wat around the rest of it. Dont be scared to give it some. Helps also if somebody else holds the door in place while you do it."
Old Jul 3rd, 2002, 08:04 PM
OK, I just did it and I was just being a big baby.
The panel (I'm going to start calling it a card) pops off with a firm yank on the top front corner.
Nothing damaged, nothing to worry about.
The door locking pin did fall out though but I can't imagine that's too hard to figure out as soon as I get a flashlight.
Old Apr 2nd, 2007, 06:45 PM
Local Time: 10:40 AM
so on my early 2004S, to remove the door panel I remove the 3 torx screws then use the techniques noted above?
Old Apr 3rd, 2007, 09:54 AM
chris.lamb's Avatar
United Kingdom Male View chris.lamb's Chili Red & White 1st Gen MINI Cooper S Profile
I have found that this tool :-
Plastic Spatula: Fine Tools Online Store
Is very useful for levering trim off cars without stratching the paint or the trim.
Old Apr 3rd, 2007, 08:04 PM
England Male View bright spark's Chili Red & White 1st Gen MINI Cooper Profile
The method i use to remove the door cards, once three torx screws are removed, is to open the door fully and wind the window down fully. Bending down use one knee to hold the door at the very bottom on the metal part to stop it moving once the tug of war starts. Remember do not hulk it off as there is a wire attached to the bottom of the door for the puddle lights and the door lock indicator thing ( technical language i know ). On the top of the door, near the hinge, there will be a raised bit. Grab this now the window is down, pull in bursts i used the lethal weapon on three which will result in the tweeter surround popping off if you havent already removed. Good look the rear panels are the interesting onces to remove you can do it use the force!
Old Apr 3rd, 2007, 10:33 PM
thanks for the assists. It'll be a week or so before I can try this....
2005 door panel removal GaryM First Generation Interior & Ice 6 May 26th, 2009 02:24 PM
door panel removal problem Adam cook First Generation Interior & Ice 3 Dec 11th, 2006 08:04 PM
2005 Door Panel Removal Enlightened v2 First Generation Interior & Ice 5 Feb 25th, 2005 02:23 PM
Removal of door panel with HK system GTT 280 First Generation Interior & Ice 7 Mar 28th, 2003 10:01 AM
door panel/card removal pic plz bcbeme First Generation Interior & Ice 2 Sep 1st, 2002 02:27 PM
