Help Is Removing Handbrake - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Nov 15th, 2005, 09:06 AM
Perm's Avatar
Local Time: 10:40 AM
Hi,
Can anyone help by giving a few tips on how to remove the handbrake ( I am adding some chrome bits).
From what I have read the steps are as follows.
1) Remove the front cap ( done that)
2) Squeeze the hand brake frame and pull up ( This I am struggling with). Does it need a lot of force ? Can not feel and give in the frame when I press the frame in....
3) Leaver open the two black clips on the front of the handbrake and then lift off handbake.
Am i missing a step ?
All advise happly received.
Perm
Old Nov 15th, 2005, 10:31 AM
.Boyracer.
Guest
Posts: n/a
I want to no how to remove the hand brake too.
lee
Old Nov 15th, 2005, 10:36 AM
Perm's Avatar
I have found this site, however does not help me....... any help ?
http://www.redlinegoods.com/MINIinstall.shtm
Perm
Old Nov 15th, 2005, 10:52 AM
.Boyracer.
Guest
Posts: n/a
I am gonna go and change my hand brake now..... I let you no
lee
Old Nov 15th, 2005, 11:25 AM
.Boyracer.
Guest
Posts: n/a
I had no luck. i got the end bit off but couldnt get the leather back bit off the hand brake
lee
Old Nov 15th, 2005, 11:27 AM
.Boyracer.
Guest
Posts: n/a
I think i will just give up as this is my 3rd attempt
Old Nov 15th, 2005, 11:34 AM
Perm's Avatar
The leather bit at the end of the handbarke is attached via a tie grip on the inside. This can can not be removed unless you remove the entire handbrake.
Perm
Old Nov 15th, 2005, 11:35 AM
.Boyracer.
Guest
Posts: n/a
So do i have to pull the leather up to get to this ?
Old Nov 15th, 2005, 11:36 AM
.Boyracer.
Guest
Posts: n/a
Will i be able to get the leather back down the edges ok or is it hard to do ??
Old Nov 15th, 2005, 11:41 AM
emu_p's Avatar
Now on my 3rd Mini !!!!
England Male View emu_p's Pepper White & Black 1st Gen MINI One Diesel Profile
I have a word doc with all the instructions that came with my leather boot upgrade
but have not got them to hand at work will look them out tonight.
but it is a very simple process but as mentioned above both the handbrake and the gaer stick have hidden tie wraps!!
Old Nov 15th, 2005, 11:43 AM
.Boyracer.
Guest
Posts: n/a
OK cheers mate, would it be possible for u to email it or even just post it on here
lee
Old Nov 15th, 2005, 12:22 PM
.Boyracer.
Guest
Posts: n/a
Done it
Old Nov 15th, 2005, 01:34 PM
Perm's Avatar
Any tips ?
Perm
Old Nov 15th, 2005, 03:11 PM
.Boyracer.
Guest
Posts: n/a
The best tip i could give you would be:
Unclip the cable tie that holds the leather onto the hand brake then it just slides off.
Lee
  #15 (permalink)
Old Nov 15th, 2005, 03:58 PM
Perm's Avatar
Did you unclip it by removing the handbrake and then unclipping it from the inside ?
Perm
Help needed removing Gear/Handbrake Gaiters JayM2 Second Generation Interior & Ice 10 May 3rd, 2007 10:01 AM
Handbrake help ringo Australia 12 Jan 19th, 2005 07:28 PM
Removing handbrake fitting gezmedinger Maintenance & MINI Care 3 Jul 23rd, 2004 10:19 PM
handbrake dundun First Generation Interior & Ice 2 Dec 10th, 2003 05:28 PM
Removing handbrake surround Dom First Generation Interior & Ice 2 Dec 19th, 2002 12:49 PM
