Questions on OEM equipment... Hi,
First time poster on the board, I've just traded in my MG TF for a little more practicality to the tune of a MINI Cooper S which I'm picking up on Monday. It's all a little exciting and I'm already trying to plan what I can do with the sound system in my MINI.
The MINI I'm buying is a 2003 model which I believe has the WAVE cassette head unit and a factory fitted CD Changer in the boot. Reading through the posts here, I think I'm going to do either of the following, depending if it's possible:
1) I'm probably going to want rid of the cassette player (who uses then nowadays anyway), so I was thinking of buying a BOOST unit off Ebay and swapping them. Am I right in thinking that it should be a straight swap compatible with the CD changer as long as I use a new harness adaptor from a site such as newMINIstuff.com?
2) I had a Sony headunit in my TF which I am taking out before I drop the car off on Monday. If I decide to use this head unit instead of buying a BOOST head unit, will I be able to get an adaptor from anywhere to make the MINI cd changer usable with it?
Thanks for any help! |
