Oil pressure sending unit and gauge questions - MINI Cooper Forum
First Generation Interior & Ice
post #1 of 8 (permalink) Old Jul 9th, 2002, 05:30 PM Thread Starter
Local Time: 02:05 PM
Anyone know where the oil pressure sending unit/switch is?
I'm researching oil pressure gauges.
I'm resigned to removing and drilling and tapping the intercooler piping if I want a boost gauge but from what I can tell that would be for entertainment purposes only.
Seems like oil pressure and oil temp would be more useful.
Speaking of oil temp, does the Cooper S have an oil thermostat for the oil cooler or does it flow all the time?
-John
jmardy is offline
post #2 of 8 (permalink) Old Jul 10th, 2002, 03:20 AM
Dr. Bob's Avatar
Local Time: 01:05 PM
United States View Dr. Bob's British Racing Green & White 1st Gen MINI Cooper Profile
Talking Try the Blue Thunder Approach
jmardy,
There have been several threads related to this topic. The best solution that has appeared is Blue Thunder's at:
http://www.bmpdesign.com/bmw/parts/c...promini1.shtml
Dr. Bob is offline
post #3 of 8 (permalink) Old Jul 10th, 2002, 08:56 AM
Blue Thunder's Avatar
Local Time: 04:05 PM
United States View Blue Thunder's Classified Ads
Send a message via AIM to Blue Thunder
Click here to see Mini Gauge kit
The Factory pressure sending unit is screwed into the oil filter housing assembly. The actual spot is under the headers, in a small spot between the header heatsheild and some sub frame piece. Removing it requires a deep socket, (Forgot the size??) Rather than have everyone fight the removal of the O.E. switch, We removes the oil filter cap, Tapped it and installed the sending unit there. It is much simpler, requires no crawling under the mini. All of our kits use electric gauges, not mechanical. Mechanical is O.K. but I'm not a big fan of having 100 P.S.I. of oil pressure in the passenger compartment.
Most all of the name brand gauge manufacturers built some pretty accurate units now days. Even if they are a few degrees off. It's not the exact temp that is important, but that you know the difference between what was normal and what is now a low pressure situation, or over heated temp.
We should have ready to ship product in a few weeks.
My mini is bigger than yours ...
Blue Thunder is offline
post #4 of 8 (permalink) Old Jul 10th, 2002, 01:33 PM Thread Starter
Thanks for the info Dr. Bob and Blue Thunder.
I like your idea. I'll keep an eye out for your stuff.
I'm a big fan of Omori gauges by the way.
They offer orange backlighting as well. Check them out if you haven't seen them.
Omori Gauges
jmardy is offline
post #5 of 8 (permalink) Old Dec 20th, 2002, 10:50 PM
Local Time: 05:05 AM
Philippines
Do we drill the aluminum Oil Filter Cap?
Hi blue
I just purchased the BMP Deluxe Boost and Oil pres pod
Just want to know if were we drill a hole ? if its on the aluminim oil filter cap does the BMP provide the correct fitting? next I read somewhere but cant find it that he purchased an Oil Filter cap that has a hole for the sensor....whats the part number and where do i get it?
If I cant get that part is it safe to drill a hole there since its subjected to so much pressure wont it leak??
Cooper S Chili Red hood stripes 17 inch BBS, Other car Subaru WRX 02
Rolandh is offline
post #6 of 8 (permalink) Old Dec 20th, 2002, 11:33 PM
BOLT ON MASTER
suprchrgdmini's Avatar
bmp gives you everything you need to tap the oil filter cap.it is pretty much straight foward.
suprchrgdmini is offline
post #7 of 8 (permalink) Old Dec 20th, 2002, 11:47 PM
w3iwi's Avatar
Local Time: 05:05 PM
Omori seems to have a US branch that is hinting about Mini products Here.
Tom
Tom Clark -- Chili Red 2002 MCS in Clarksville, MD
w3iwi is offline
post #8 of 8 (permalink) Old Dec 22nd, 2002, 03:59 PM
Local Time: 07:05 AM
Don't think you can replace the gauges (Speedo or Tacho) as the Speedo is a major Gateway between system Buses in the car.
However changing the dial face may be a better way of going. I have seen a thread on hear about this.
snoopy is offline
