| I installed one of these yesterday. 1) Once all the wiring and kit is fed back through the head unit it's really easy to move it all to house behind the knee bolster 2) Put the mike up by the top of the a pillar and then run the wire down inside the rubber moulding - then it can go into the space behind the knee bolster and connect to the parrot box. 3) Correct - I have a Blackberry that doesn't support voice dialing. So you can answer and end calls and adjust volume. I was able to record "Hang Up" as a voice control but that was it. Great piece of kit though.....good luck. Only takes about an hour to install - if that. |
| Here's where I put mine I have the CK3000 (non-EVO) and put the mic over where the factory mic would have gone. I tried putting it IN that mounting but the sound quality was very poor. Regarding voice dialing, the CK3000 (don't know about the EVO) supports this itself so the phone doesn't have to. To train it you need to install the Parrot control pad in addition to the MFSW kit and follow the Parrot directions. I did this even though my phone supports voice dialing as the commands recorded in the phone didn't work in a moving vehicle. Using the CK3000 allows a second set of names to be recorded that match more reliably in the vehicle. -rexkp. |
| Where to hide the parrot evo bluetooth box? | MacTheMini | First Generation Interior & Ice | 11 | Jul 19th, 2009 06:43 PM |
| Parrot EVO Bluetooth Review | DaFlake | First Generation Interior & Ice | 11 | Aug 24th, 2007 07:51 PM |
| Keep My Nokia CK7W Or New Parrot Evo ?? | JDinho | First Generation Interior & Ice | 6 | Aug 17th, 2006 12:48 PM |
| Parrot 3000 Evo and Blackberry 7100 | timc01 | First Generation Interior & Ice | 8 | Jan 9th, 2006 02:06 PM |
| Mounting a microphone in the sunroof | Boogy | First Generation Interior & Ice | 0 | Jun 2nd, 2005 10:05 PM |
