Fitting Chrome Interior... - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 16th, 2006, 10:12 PM
baskers's Avatar
Local Time: 10:42 AM
Bought the chrome bits from newministuff.com last month and am worried about screwing things up in my new motor by fixing it and breaking it.
Has anyone got any advice on how to fit these... does it screw on/off, clip on/off need glue or dismantling?
Or would the dealer fit it for me, I know they'd charge...
Jay
Old Jan 16th, 2006, 10:22 PM
Paul's Avatar
MINI2 No.1
England Male
Which bit(s) did you get?
Old Jan 16th, 2006, 10:24 PM
baskers's Avatar
The lot from this page:
https://www.newministuff.com/new/sho...uctshow&id=114
Old Jan 17th, 2006, 02:30 AM
WEEGIT's Avatar
MINI Convert
Local Time: 03:42 AM
United States Male View WEEGIT's Pepper White & Black 1st Gen MINI Cooper S Convertible Profile
I'm attempting to dechrome (go to anthracite).
So far, I've replaced the following:
Air vents: easy twist (CW or CCW?)
Cup holder (dual ring): gently pry up one edge
Hazard/dash light: gently squeeze sides and pull out
Gear surround: gently pry up one edge, plate (if auto) and shifter boot comes with it, turn over and find tabs (3 I think)
I've NOT replace the following yet:
Speedo: replacement ordered, need direction
Rev counter (Tach): replacement ordered (I was told it's available in silver only, may try to paint it or may leave it as is cause theres a lot of silver near by), I've read and seen photos, remove tach, cut paper label at seam, remove back, trim tabs are exposed
Handbrake handle: I think the handle's leatherette boot and plastic trim on the tunnel has to come out, there's a screw under the rubber mat in the recess just below the button, haven't had time to venture further, may leave to the dealer when other work is done
Hope this helps
Erik and my SoCal Cruiser
06 PW/B MCSC ZSP, ZPP, ZCW, AT, Space Grey cloth, F/R fogs, WMS-15%+2%, JCW brakes & STB, DINAN 19mm, R90s (anthr), WD, EPS, G&G
Old Jan 17th, 2006, 05:44 AM
Baker's Avatar
Being normal is not fun!
Local Time: 09:42 PM
Australia Male View Baker's Dark Silver & Body Color 1st Gen MINI Cooper S Profile
Read the guide Paul posted a while ago (search, not sure if its in the FAQ), its pretty easy to follow.
Old Jan 17th, 2006, 06:53 AM
mikeythemini's Avatar
Local Time: 11:42 AM
As Baker said there is a good guide on here
IF you get stuck with any bits ring me while sat in the car & I will talk you through
Old Jan 17th, 2006, 07:26 AM
baskers's Avatar
Cheers Mikey - need to find this guide Paul posted...
Old Jan 17th, 2006, 07:34 AM
baskers's Avatar
Found it on the FAQ, but it's pre 2005, and mine's a 2006
Old Jan 17th, 2006, 07:43 AM
Baker's Avatar
Its all the same mate
Old Jan 17th, 2006, 07:50 AM
baskers's Avatar
I am not taking the frigging dash off of a £16,000 motor!!! It's going to the dealers, it's probably a piece o'cake, but I have a habit of ballsing things up!
Old Jan 17th, 2006, 07:53 AM
Baker's Avatar
Its really not that hard mate... think of us over here in Australia, we pay a *lot* more for our Mini's over here!
In all honesty, I did it in bugger all time - but I know my way around the dash. If you didn't, it'd still take you around 1-1.5 hours!
Old Jan 17th, 2006, 08:47 AM
Paul's Avatar
MINI2 No.1
England Male
Do all of it APART from the speedo ring at least.
It is possible in many cases to just pry the speedo ring off (so I hear on here), but you just have to make sure you're careful not to damage the areas around it with whatever lever you decide to use.
Old Jan 17th, 2006, 10:45 AM
baskers's Avatar
Paul,
Thanks for that - I have actually just booked the car in to have soley the speedo ring put on. I am taking the chrome speedo down to them tonight, and it'll be put on the car tomorrow.
I actually pick the car up tomrorow night now! They've charged me labour of £120, absolute day-light robbery, but whoelse could I get to do it... and at the end of the day, they're the experts.
I should be able to fit the others sans problemes...
Jay
Old Jan 17th, 2006, 10:47 AM
Baker's Avatar
You could have got Mikey to do it he knows more than BMW when it comes to fitting things in Minis
  #15 (permalink)
Old Jan 17th, 2006, 10:48 AM
Paul's Avatar
MINI2 No.1
England Male
£120! You might want to try and pry it off with your finger nails if you can, SOME people have found it easy enough to actually just do by hand. If you can do that it's got to be worth a few minutes of your time to save £120. The new one will just press on.
Fitting Chrome interior gikster First Generation Interior & Ice 3 Nov 21st, 2006 07:49 PM
Fitting the Chrome interior parts Mini Seven First Generation Interior & Ice 2 Oct 10th, 2006 11:39 AM
Fitting Chrome kits CoolCarStuff First Generation Interior & Ice 3 Oct 5th, 2006 12:24 PM
Problems fitting interior chrome kit? Cooperchris First Generation Interior & Ice 3 Jan 7th, 2005 05:38 PM
Fitting interior chrome rings Red Dwarf First Generation Interior & Ice 1 Mar 21st, 2004 12:45 PM
