New MFSW relays We now have some relays in stock to make use of the phone button on the later 3 spoke MFSW (for those of you without a linked phone kit) The first allows you to use it to trigger your garage door remote (requires you to open up your garage remote & join in 2 wires from my relay) The second can be used to mute your radio/cd We do both variants in spice version (you can get all the wires behind the radio) or plug & play (plugs into the radio) www.newministuff.com |
| I like the garage door relay idea. I have Ian's Switch that does the windows and works with the lock toggle for the Garage door. I couldn't find the info on these on you site. Maybe because I was too busy drooling over everything else... ![]() What section are they in? I found 'em... https://www.newministuff.com/new/sho...uctshow&id=261 |
| Mikey, I'm thinking of using your MFSW garage door relay for a different application. I installed the OEM rear view camera (purchased from you!) and it's a great mod. The finishing touch I haven't done yet is to install a switch that would enable on-demand viewing of the camera (normally enabled only when the car is in reverse). I know how to set it up (the circuit diagram is here). Using your relay as the switch, the steering wheel would be a great location to operate it. I will probably do this as a minimum, and it would allow me to momentarily view the camera while I'm pressing the button. As a further enhancement, it would be fantastic if the button could be made toggle the relay on/off. What would be required to do this? I am willing to add circuitry myself but could use some help to design it. Richard |
| Is the relay hardwired to the phone button, or is there a possibility to use the R/T button? Can one relay be installed for the phone button and another relay for the R/T button, to control two different functions? |
| Interesting Mike ... like that circuit I made and sent one of to you long ago ... you've found a new circuit maker now?! |
| Fuses, Relays & Earth Points | mab01uk | Maintenance & MINI Care | 13 | Dec 18th, 2011 12:27 PM |
| Mfsw | The_length | First Generation Interior & Ice | 5 | Apr 8th, 2006 11:51 AM |
| Relays and Toggle Switches | snek | First Generation Interior & Ice | 37 | Mar 22nd, 2004 11:38 PM |
| New MFSW | Cooper i Do | First Generation Interior & Ice | 3 | Oct 9th, 2003 02:23 AM |
| Mfsw | dbmb | First Generation Interior & Ice | 20 | Nov 21st, 2002 05:52 AM |
