Fascia around heater controls - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 23rd, 2006, 03:49 PM
MarkWMC's Avatar
Local Time: 10:44 AM
Anyone know how to remove the above!
Thanks a lot!
Old Feb 23rd, 2006, 04:02 PM
Lost in Mini2
Send a message via AIM to "Reedy" Send a message via MSN to "Reedy"
Local Time: 11:44 AM
United Kingdom Male View "Reedy"'s Astro Black & Body Color 1st Gen MINI Cooper S Profile View "Reedy"'s Classified Ads
I think u have to start with removing the down tubes either side, then u can get access to the rest of the facia. I read it somewhere, will try and find it.
Check out the DIY section for removing the down tubes. you should be able to get access to heater control and remove it then. How u then put those nice shiny chrome bits on, i'm not sure.
JCW Black R105 - JCW Strut - More Mods Soon...
Old Feb 23rd, 2006, 04:08 PM
MarkWMC's Avatar
Hmm....ok then!
Thanks!
Old Feb 23rd, 2006, 04:45 PM
Root Ginger's Avatar
Amiga 500 to PS3 20 Years
Follow instructions for removing dash down tubes HERE.
Remove the four screws holding in head unit and remove unit. You can then undo two screws holding in heater controls. You need to remove two of the clips that the dash down tube screws into (normally blue) that are either side of the heater controls. Should be able to then release the heater control clips and push the whole unit back (may need to disconnect the heater cables beforehand). You then have to manoeuvre and twist the heater controls to get them out. Awkward job but easier than putting it back in again
Once removed you will find the fascia is clipped on.
It was acceptable in the 80's
Old Feb 23rd, 2006, 07:46 PM
MarkWMC's Avatar
Thanks a lot for your advice. It seems a bit to tricky for me though, so I will get someone to do it!
heater fascia.. drumzz First Generation Interior & Ice 0 Apr 17th, 2007 08:09 PM
Alloy Heater Controls MarkWMC First Generation Interior & Ice 26 Apr 15th, 2006 04:40 PM
headunit and heater controls paulno1 First Generation Interior & Ice 1 Jan 7th, 2005 02:28 PM
