| Hi John Im not sure about the actual fascia panel on the heater panel coming off. However, it might be easier to work on it on a bench with the whole unit removed? The heater assembly comes out as a unit. You will need to remove the downtubes to access the retaining screws, its the same procedure as is used for removing the radio head unit. |
| How to replace a blown bulb in the heater control panel | oldnell | First Generation Faults & Fixes | 9 | Oct 17th, 2011 12:04 AM |
| Directions to remove driver side kick panel R56 | timekpr | Second Generation Interior & Ice | 0 | Jul 24th, 2007 04:10 PM |
| Remove sunroof control panel | n00b | First Generation Faults & Fixes | 4 | Sep 12th, 2006 06:50 PM |
| Block Heater, or Oil Pan heater? | ChilliSteve | Canada | 1 | Nov 17th, 2003 10:54 PM |
