| I have replaced my door pins with flashing red LED's in the doors. I removed the pins by taking off the inner door trim casing and then disconnecting the meatl rod from the lock mechanism. It simply pushes/unclips out of the lock and then it can be threaded out of a small holed grommet in the metal door panel. |
| Ian, They don't flash @ all @ the moment as theye are not wired in. The idea was to bget them to flash with the Alarm LED in the Column Stalk but the connection required is elusive.......... This look good not lit as only the hemispherical end of the LED shows in the hole in the bezel. Chris |
| Chrome door lock pins | rabbit | First Generation Interior & Ice | 5 | Mar 12th, 2007 12:39 PM |
| Just Fitted My 'S' Door Pins :-) | zanhar25 | First Generation Interior & Ice | 8 | Dec 21st, 2006 12:54 PM |
| Flashing LED Door pins | Blusox | First Generation Interior & Ice | 5 | Aug 13th, 2005 11:41 AM |
| Aluminium door pins... (door lock buttons) | GTT 280 | First Generation Interior & Ice | 3 | Jan 12th, 2003 06:31 AM |
| Door lock pins | monsta | First Generation Interior & Ice | 11 | May 3rd, 2002 04:25 AM |
