Interior Painting questions - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 15th, 2006, 04:12 PM
Richard22b's Avatar
MINI Mad
Send a message via MSN to Richard22b
Local Time: 11:08 PM
United Kingdom Male View Richard22b's Classified Ads
Yellow Cooper Interior Painting questions
My MINI is Liquid yellow and i want to paint the dash the same colour. what can i buy that matches the colour or what shall i use.
Old May 15th, 2006, 06:24 PM
Root Ginger's Avatar
Amiga 500 to PS3 20 Years
Get your local car shop to mix up some liquid yellow and use that. You'll need to use a fine grade on sandpaper to get the paint to key to the dash. It would also be worth using a plastic primer too and finish off with clear lacquer.
It was acceptable in the 80's
Old May 16th, 2006, 01:28 PM
Richard22b's Avatar
MINI Mad
hi. thanks for the info.
what sorta car shop can mix the paint. i am unsure of one in Bristol
Old May 16th, 2006, 02:04 PM
:: Jon ::'s Avatar
Scotland Male View :: Jon ::'s Classified Ads
not many if any...
its got to be a paint shop.. or a bodyshop... go to your local bodyshop and ask where they get there paint supplied from and they point you in the right direction
Old May 16th, 2006, 02:13 PM
Richard22b's Avatar
MINI Mad
Quote: Originally Posted by Jonmorgan
not many if any...
ah well, will have to ask around
Old May 16th, 2006, 02:33 PM
You need to go to an independent motor factor. The ones near here are called Motorist Discount Centres. They'll be able to make small batches of paint from the paint code under the bonnet and put it into an aerosol or tin for you.
Old May 16th, 2006, 10:42 PM
jamiebae's Avatar
Not all paint suppliers can do aerosols. I work for the largest paint/bodyshop supplier in the UK and most of our branches don't do aerosols, they just mix the paint in pots.
I'd head down to Halfords and get a couple of cans of plastic primer, some liquid yellow paint (it won't matter if the match is slightly out because the dash doesn't touch the bodywork anywhere so it won't notice) and some clear lacquer.
Old May 16th, 2006, 11:21 PM
Pobsey's Avatar
The de Chromed MINI
Send a message via MSN to Pobsey Send a message via Yahoo to Pobsey
Local Time: 10:08 PM
United Kingdom Male View Pobsey's Dark Silver & White 1st Gen MINI Cooper S Profile View Pobsey's Classified Ads
Halfords can mix paints, but their colour charts/computer is out of date and doesnt have the MINI colours on it (or at least the Halfords in Altrincham didn't)
Old May 17th, 2006, 07:48 AM
[quote=jamiebae]Not all paint suppliers can do aerosols. I work for the largest paint/bodyshop supplier in the UK and most of our branches don't do aerosols, they just mix the paint in pots.[quote]
Ok, I guess I'm just lucky where I live then.
Old May 17th, 2006, 07:50 AM
This is true, Halfords don't do any of the MINI colours. I've tried a few different branches before and then had to turn to my local motor factor who mixed some up for me.
Old May 17th, 2006, 02:28 PM
mike4's Avatar
i would pay for a pukka job, you can always tell when its been sprayed at home. take the bits off yourself take them to the spray shop, ask for a cash job.
Old May 17th, 2006, 07:49 PM
Electric Blue's Avatar
VERY good advise. I think there is a company called "Dash of Colour" or something like that who specialise in painting dashes. Would be worth getting the job done by a pro, then you won`t be disappointed. I have tried painting similar items before and foudn the results a little lower than I wanted, thus making me pay for them to be done properly afterwards.
If it wasn`t something right infront of your face it wouldn`t matter too much, but a dash needs to be done right.
Old May 17th, 2006, 11:54 PM
Richard22b's Avatar
MINI Mad
if you can remember the company it would be great
Painting interior parts to combine with JCW carbon?? Maaij First Generation Interior & Ice 2 Nov 26th, 2006 06:58 PM
Painting Interior Pieces kcchadmac First Generation Interior & Ice 3 Aug 10th, 2006 01:29 PM
US '05 Cooper S Interior Lighting Questions acande1 First Generation Interior & Ice 6 Nov 16th, 2005 09:32 PM
About to order: Interior questions mattharris75 First Generation MINI Cooper S 11 Feb 25th, 2005 03:48 AM
**Painting interior silver bits....HOW do I remove Speaker grill??? JamesBond First Generation Interior & Ice 15 May 13th, 2004 09:24 PM
