| The rubber door trim just pulls off then you just have to be a bit brutal and pull the plastic. The clips sometimes stick in the bodywork so you need to lever them out and put back in the trim before refitting. The one right at the rear below the side window by the seat belt is the worst and watch out for the metal clips at the top of the rear trim. You can reach through from inside the rear cover from the boot. Make sure you run the cables under the carpet. Took me about an hour including removing the front pillars etc to attach to head unit. Hope this helps |
| Cable Routing | el_corpo | First Generation Interior & Ice | 4 | May 9th, 2007 04:48 PM |
| cd changer cable | Coopy | First Generation Interior & Ice | 4 | Mar 5th, 2007 06:23 AM |
| Routing Icelink dock cable into glovebox with AUX-in port | Cardo | First Generation Interior & Ice | 9 | Nov 5th, 2006 11:29 AM |
| Routing amp cable??? | Devilman | First Generation Interior & Ice | 2 | Nov 17th, 2003 03:17 PM |
| Changer Cable | MINIALEX | First Generation Interior & Ice | 1 | Aug 27th, 2003 08:37 AM |
