HELP! Mini Cooper amp install Hi there, Has anyone installed a amp in a mini cooper, i am trying to do so but I cannot see how to feed the power cable from the Battery in the engine bay to the boot. Please help. Many Thanks |
| A quck search through the forums for firewall / fire wall and amp gave me ... http://www.mini2.com/forum/758735-post2.html and http://www.mini2.com/forum/692429-post112.html But usefully the search reminded me of ScooterBoy, a local MINI owner that did an audio install how-to on his website: http://home.comcast.net/~sfconnell/mods/audio/home.htm It has a link to "running power cable from engine to cabin" which links to: http://www.mini2.com/forum/interior-...ing-holes.html ScooterBoys web site also has pics ... http://home.comcast.net/~sfconnell/m...dio_page_2.htm I think this last is probably exactly what you need ... all it requires is searching |
Hi there, Yes, i think i can help, i wish i had some photos to show you as it would be a lot easier but alas, i don't. Ok, with the bonnet up, look into the far left corner, you'll need a torch. Look behind where you top up the brake fluid, you should see a rubber grommet with some black conduit coming out of it. Carefully, make a small hole in the grommet next to the conduit. You will be able to put your power lead through the hole, look under the dash inside the car by the driver's footwell, you should see the power cable coming through. I re-sealed around the hole in the grommet with some silicon sealer, just in case. You can run your power cable from the battery +, across the top of the battery, and out where the negative cable leaves the battery casing. I cable tied the power cable by the brake pipes just to keep things tidy. The fuse holder will be exposed to the rain from the black vents by the windscreen, however, i took this route becase the fuseholder is waterproof, and i didn't want the power cable running inside the engine bay. Hope this helps, Adrian. |
| MINI2 exclusive - 2007 MINI Cooper & S Design Comments & Photographs.. | Paul | Second Generation MINI Exterior | 30 | Oct 20th, 2006 05:41 AM |
| Install a Pipercross PK222C on a mini cooper 08/2004????? | Red_Devil | First Generation MINI Cooper | 4 | Aug 28th, 2006 09:33 AM |
| Install a Pipercross PK222C on a mini cooper 08/2004????? | Red_Devil | First Generation MINI Tuning | 1 | Aug 19th, 2006 01:08 AM |
| I want to install neon headlights for my 2005 Mini Cooper | Ryanhuaxia | First Generation MINI Exterior | 3 | Jul 21st, 2006 03:07 AM |
| amp install in left & right panel of boot? | Galvatron | First Generation Interior & Ice | 34 | May 9th, 2003 02:15 PM |
