Mini sat Nav - Page 2 - MINI Cooper Forum - MINI2 Mini Cooper Forums
  #16 (permalink)
Old Mar 10th, 2009, 11:11 PM
DaFlake's Avatar
MMC Member
Local Time: 04:47 PM
First, make sure you burn the CD in mode 2 . The MK3 is very picky.
Second, the NAV unit is behind a plastic door under the passenger seat. You will need to lift the plastic door.
You are a few versions out of date so this will get you caught up. After this one there will be no further updates needed.
  #17 (permalink)
Old Mar 11th, 2009, 05:32 PM
Local Time: 10:47 PM
United Kingdom Male View brizza1982's Classified Ads
Hi all,
Finally found the disk... It was under the driver seat... I put the updated firmware disk in and booted it up, then, disaster struck... the screen went black... and has been even tried putting the old disk back in! help!!!!
  #18 (permalink)
Old Mar 11th, 2009, 06:16 PM
aaarrggghhh, even worse! it wont even eject the disk now! bad to worse! Heeeeeeeeeeelp!! please!
  #19 (permalink)
Old Mar 11th, 2009, 07:04 PM
DaFlake's Avatar
MMC Member
OK, you didn't burn the disk in mode 2..... So, what you will need to do is disconnect the battery for a while and then press and hold the eject button once you reconnect. After that, pop in the newly burnt mode 2 disk and it should start to update.
Don't use CD-RW... Only use CDR as well. The MK3 is old technology and can't read those well.
  #20 (permalink)
Old Mar 11th, 2009, 10:06 PM
Fantastic!!! got the computer back up and running and upgraded the firmware!!! man that was scary! thanks so so much for the help guys!!! The little mini is awesome, I have a Renault 5 GT turbo running around 280bhp and have just written off an E36 M3 so this car is perfect with the handling and nippiness of the 5 yet the comfort and build quality of the BMW. thanks so much again guys
  #21 (permalink)
Old Mar 11th, 2009, 10:11 PM
DaFlake's Avatar
MMC Member
Glad you got it up and running. You're welcome.
  #22 (permalink)
Old Mar 31st, 2009, 03:05 PM
Does this download v32 extract to 1 .iso file and then is this the file you burn?
Is it to be used on the mkiv system?
  #23 (permalink)
Old Apr 2nd, 2009, 05:12 PM
Local Time: 12:47 PM
Vanessa1,
yes that is the file you need to burn to CD with your favorite burning app. I used nero to burn the image.
  #24 (permalink)
Old Apr 18th, 2009, 03:24 PM
England Male View Westy66's Sparkling Silver & Black 2nd Gen MINI Cooper S Clubman Profile
Got an 08 plate Clubman coming next weekend. Will that need updating ?
Westy
  #25 (permalink)
Old Apr 18th, 2009, 07:01 PM
DaFlake's Avatar
MMC Member
Westy
No, and it is a different NAV computer than the 1st gen.
  #26 (permalink)
Old Apr 19th, 2009, 09:59 AM
Thanks for that
What are the specs on the version fitted to mine - manufacturer, model etc.. ?
Westy
  #27 (permalink)
Old Apr 23rd, 2009, 12:46 AM
Local Time: 09:47 PM
Hi
I have just purchased a 2005 Convertibe with a DVD drive, it has an old edition of the software 02-2004 I think?
I was wondering if there are any downloads or recommendations in relation to updating this information.
Thanks for help
Vaughn
  #28 (permalink)
Old Apr 23rd, 2009, 01:45 AM
DaFlake's Avatar
MMC Member
There are two types of "software" the map data and the firmware.
The CD or DVD in your drive is map data and must be purchased from either Navteq or BMW. Updating this will give you better road coverage.
The firmware is loaded via a CD that you will burn and is usually done via a dealer. You can get the latest V31 at Simply MINI if you are interested.
  #29 (permalink)
Old Apr 23rd, 2009, 04:38 AM
Smile
Hi all
Just been on the Just Mini site as recomended by DaFlake and there is version V32 just posted if anyone is interested.
Westy
  #30 (permalink)
Old Apr 23rd, 2009, 12:24 PM
DaFlake's Avatar
MMC Member
Tis my site and I posted it there.... I used to have it up and running a year ago but I let it fall apart. I figured I would get it back up and running again.
R53 Sat Nav vs R56 Sat Nav Perm Second Generation Interior & Ice 34 Jun 22nd, 2008 05:16 PM
Mini Sat Nav scottybhoy First Generation Interior & Ice 0 Oct 5th, 2004 12:04 PM
Mini Sat Nav jasonhendry First Generation Interior & Ice 19 Jul 25th, 2004 05:19 PM
Sat Nav Available with Mini ONE? Rich_IX First Generation MINI One 2 Oct 13th, 2003 10:46 PM
Non Sat-Nav cars: Utilised Sat-Nav area WAY First Generation Interior & Ice 1 Nov 1st, 2002 03:46 AM
