ICE Link Plus - help - cannot access the Menu (Disc 6) - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Aug 14th, 2006, 05:31 AM
BlueMax
Local Time: 03:44 PM
South Africa View BlueMax's Electric Blue & White 1st Gen MINI Cooper S Profile
I have installed the ICE Link Plus in my MCS two weeks ago. Works brilliantly except that I cannot access the Dension menu (Disc 6 selection). I have setup 5 playlists, random play works, MFSW controls work, all except the menu. Got the menu once at initial installation (after a struggle) and I have set up the volume, charging options etc. I have disconnected the car battery (short and long periods), disconnected the plug from the wafer, tried my other Ipod - no luck. I installed an ICE Link in my Renault Scenic 1 last weekend, everything works with both my Ipods. Does anyone know how I can get the menu back? Thanks
Old Aug 14th, 2006, 06:03 AM
mikeythemini's Avatar
Local Time: 02:44 PM
Do you have text working on the stereo?
Old Aug 14th, 2006, 07:32 AM
3xpt0's Avatar
MOD Background
Portugal Male View 3xpt0's British Racing Green & White 1st Gen MINI One Diesel Profile
The same here
Radio Boost ( With text supported ) ... I click on CD6 after 1 sec to enter the setup he changes to CD1 auto doesn't let me enter the setup.
Old Aug 14th, 2006, 08:40 AM
DaFlake's Avatar
MMC Member
Local Time: 09:44 AM
Did either of you tell the Icelink to send control to the Ipod itself? If so, then the menu appears on the HU and not on the Ipod until you switch it back.
Old Aug 14th, 2006, 08:42 AM
3xpt0's Avatar
MOD Background
My control is on the Radio Boost screen ...
Old Aug 14th, 2006, 08:44 AM
DaFlake's Avatar
MMC Member
Meaning that you can control the Ipod with steering wheel controls?
Old Aug 14th, 2006, 11:03 AM
Yellow and Proud
Send a message via MSN to MartinSSZ Send a message via Skype™ to MartinSSZ
United Kingdom Male View MartinSSZ's Liquid Yellow & Black 1st Gen MINI Cooper S Profile View MartinSSZ's Classified Ads
How would I go about changing the 'control' option? I've got an IceLink Plus kit which won't show the menu either - here's hoping I can change an option to get it to work
Old Aug 14th, 2006, 11:21 AM
BlueMax
I have the earlier Boost H/U that does not support text. When I could still access the Dension Menu, control was set to the H/U and not the Ipod to allow control from the H'U and steering wheel. I can change from CD 1-5 for the playlists 1-5 and change tracks within CD 1-5. If I press 6 it just displays 6 and the track number it was playing on CD1-5 at the time. After a while it just goes back to the CD number it is playing. It does not go into the menu. I think I tried at some stage when I could still access the menu to see if the H/U would support text and nothing happened. I then switched off and unplugged and since then disc 6 button has not been doing anything. The screen display on the Ipod is the Dension display as I am not controlling via the Ipod. It comes up with the Warning not to browse, random works, charging works etc., only the menu is not displaying
Old Aug 14th, 2006, 11:38 AM
DaFlake's Avatar
MMC Member
Do you guys happen to know what version of Firmware you were running? This might be an issue.
Old Aug 14th, 2006, 11:40 AM
DaFlake's Avatar
MMC Member
Let's beat on this one piece at a time.
Old Aug 14th, 2006, 01:16 PM
BlueMax
I will report on the firmware issue tomorrow, I assume it will be the latest, bought the kit 2 weeks ago. Strange that it did work and all other functions are perfect. Is there a way to reload the software (to reload / repair) the firmware. I do not know how to put that. It was the next thing I wanted to try. I am not sure if it may have been corrupted when I tried to setup the text display on the H/U. I have contacted the local agent, they have no idea. Apart from the menu problem I am extemely satisfied with the Ice Link Plus. I installed a Ice Link FM on the Scenic because I was told that the Plus does not work on Scenic 1's - I was not happy with it - low volume, signal break trhough etc. Then tried a Plus for a Scenic 2 and it works brilliantly on the Scenic 1 - even the menu works and even simpler to install than on the Mini.
Old Aug 14th, 2006, 01:30 PM
DaFlake's Avatar
MMC Member
Several things I do want to point out. First, the menu on the unit is SSSSLLLLOOOOWWWW. You have to take your time and it may be that you are jsut getting frustrated (like I did at first) and clicking too fast. 2.B2 is the lastest for the MINI and if you are not running it, you should. Lastly, if you select to control the songs via Ipod, you will loose the menu from the Ipod and it will only appear on the HU. At this point you have to re-select the radio as the control unit and it will return the menu to the Ipod.
I hope that some of this helps a little.
Old Aug 14th, 2006, 06:07 PM
If you have tries selecting text & your stereo doesn't do it then this may well be your problem. The icelink is in text mode so all the menus are now being sent to the stereo which you can't see as your stereo doesn't do text. You need to run the no text firmware file to reset it.
Is this the old style icelink plus (circuit board in heat shrink)
Or new icelink plus, circuit board in plastic case
Old Aug 15th, 2006, 06:27 AM
BlueMax
Thanks Mikey, I think you are absolutely correct - I lost the menu off the Ipod screen after I tried to see if text display will work on my stereo. I have read the booklet again and there is a statement under BMW special functions page 10 that now makes sense 'Use the BMW_Text_disable.mp3 config file to disable text display. This can be helpful if you made a wrong selection and nothing is displayed.' I have version 2-2b of the firmware and the circuit board is in heat shrink. Now 2 questions remain:
1 Where do I get the config file?
2 How do I run the file to reset the firmware?
Flakemeister, thanks for your input, I know the menu is slow but it is not the problem in this case, it must be text being sent to the stereo that cannot display it.
Pls help an ICE noob with ICE Link quesitons deroo First Generation Interior & Ice 9 Oct 17th, 2006 05:24 PM
How do i tune the radio in? (Access OEM Hidden Menu) funkcityb First Generation Interior & Ice 4 Aug 1st, 2006 01:52 PM
ICE Link Plus - HELP!! Andrewturnill First Generation Interior & Ice 2 Sep 16th, 2005 07:09 AM
Ice>Link: Plus -- '05 MC HK beetle First Generation Interior & Ice 6 Aug 12th, 2005 01:21 PM
New Ice-Link now available azimmerm First Generation Interior & Ice 6 Apr 14th, 2004 04:01 PM
