CD Changer Socket I know it may be a dumb question, but I've spent last 3 hours trying to figure it out on my own with not much luck. I want to install new Dice Electronics Ipod controller on my 2005 Cooper S with HK (no Nav). I know the CD Changer socket should be near the HK amp on the right side of the trunk. But there is none! I even took out the back seats and side trim (hoping to lay the wire properly after I find the connector), but there is no socket! Does anybody know any other place it could be in '05 MCS w/HK? Please help! |
| When i fitted this to my 54 cooper it was located in the cubby whole you mean but was taped down quite heavily. All you could see was the small black connector/connectors? I had to remove some of the binding to gain access to the wires. I hope this helps Checkie Checkmate mad owner |
| Went to the service dept today and they said that those CD Changer cables just no loger being installed in newer models. Duh?! So, now to wire it all I'd have to buy $107 cd changer wire kit. and run both or them through the car (or cut and solder). This is just nuts! |
| I know it was an option on pre face lifted versions but i was pretty sure they changed it during the face lift so every car had it. Ask another dealer me tinks. Checkie Ps going to go check my car now! he he Checkmate mad owner |
| I just checked my 06 MCS checkmate with H/K and i've got it, pics bellow It's under the second piece of white tape on the right. it's a small 1 cm by 0.5 cm connector. Thats how i would describe it. Sorry for poor quality used my bone: Checkie Checkmate mad owner |
| Thanks Checkie. I know which ones you are talking about as I saw it in another Mini at the service center. But those are definitely missing on mine. And the dealer says that's the norm... But from what I can see, I'm totaly out of luck... Also, can't find those R40 Head unit connectors being available anywhere on the net. Probably may try and check with some wreckage companies.. |
| 12v socket in boot | blueyeswill | Second Generation Interior & Ice | 6 | Apr 11th, 2007 11:07 PM |
| Diagnostic Socket? | cliveyboy8 | Maintenance & MINI Care | 2 | Sep 12th, 2006 06:07 PM |
| 12v Socket | miniman23 | Second Generation Interior & Ice | 5 | Sep 10th, 2006 07:05 PM |
| MP3 CD-Changer that will fit directly into a 'CD-changer prepped Cooper' ? | ADO15 | First Generation Interior & Ice | 2 | Jul 31st, 2003 12:44 PM |
| 12V socket | Jonny Wells | First Generation Faults & Fixes | 2 | Jul 16th, 2003 09:29 AM |
